Instruments and Amps Everything that makes music, Especially including instrument amps.
Vari-mu compressor question - Side chain
Old 12th November 2012, 10:55 AM   #11
DF96 is offline DF96  England
If there is an overlap between the lowpass filter action of the AGC chain and the highpass filter action of the main signal path then you have an unstable loop. If you want a quick response then you have to exclude low bass from affecting the compression.
Old 12th November 2012, 11:40 AM   #12
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
There must be an overlap, at fast attack times it is very unstable. So I should address that before moving on.
It does perform very well apart from that, but it would be a much better comp if it was a bit quicker. I assume there is a way to do this.... But then a vari-mu will never be as responsive as a optical I guess.
Broke solderer with delusions of grandeur
Old 12th November 2012, 11:52 AM   #13
Vari-mu valves operate quite well up to 1GHz so that is not the issue. The issue is loop design and passive component values. You can't have a quick response on bass frequencies, except perhaps by using a signal delay so that causality ceases to be a constraint.
Fast servo loops are difficult to get right.
Old 12th November 2012, 04:57 PM   #14
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
It is not uncommon for the combination of fast attack/release times and low bass notes to cause instability. The reason is simply that the with fast attack/release times, the gain control voltage will actually follow the waveform of low bass notes and causes them to be flattened. It is equally common to include a high pass filter in the side chain to prevent this happening.
Cheers
Ian
Old 13th November 2012, 07:51 AM   #15
Brouilly's Avatar
Good to hear from you Ian.
I guess it depends on how much the instability is a problem, and if actually it is just part and parcel of the vari-mu design and sound. I will aim for a good balance between stability and fast attack/release - I thought it was worth asking as there might be another approach to get quick settings and stable bass.
I have a high pass filter at 50,75,120,250,300 which I found to be the most useful frequencies and the unit has no stability problems with that in. I am also finding that the release is a little bit sluggish in mid settings, so I imagine some experimentation with the discharge time of that cap will give better results.
Thanks, learning lots.
Charlie
Old 13th November 2012, 10:04 AM   #16
You can get the best response by ensuring that the loop design is excellent, with a dominant pole and other poles much higher in frequency. The temptation is always to add extra smoothing so there is no audio on the control voltage. This adds phase shift and so destabilises the loop.
You could try reading up on 'hang AGC', as used in some communications receivers. Receiver AGC and audio compressors are doing almost the same thing, so techniques used in one can sometimes be applied to the other.
Old 13th November 2012, 10:12 AM   #17
disco is offline disco  Netherlands
disco's Avatar
Last year I build this compressor and experienced similar distortions on faster settings (smaller value for the .22uF).
Do I get this right:
P1 ?= amplification level
CW ?= quantity of compression
C4 ?= both attack and release times
M1 ?= indicates AC level
jaap
Old 13th November 2012, 10:37 AM   #18
Brouilly's Avatar
P1 is gain
P2 release
P3 is threshold
R12 is attack, but I have a different arrangement here.
M1 is gain reduction shown as current through input valve.
Thanks DF96, I will look into hang AGC. Better get the calculator out and make sure the poles are where they should be.
Old 13th November 2012, 11:25 AM   #19
disco's Avatar
Of course, CW= clock wise
What iron did you use Charlie?
jaap
Old 13th November 2012, 11:41 AM   #20
Brouilly's Avatar
That's an interesting thread, thanks for posting.
I have some 9:1 Sowter transformers I am using with 5965. But have just ordered some LL1689 from Per, really looking forward to hearing the difference between the two!
Vari-mu compressor question - Side chainHide this!Advertise here!
A New approach of Volume Control: AAVA (Accuphase Analog Vari-gain Amplifier) tiefbassuebertr Analog Line Level 14 4th July 2011 07:26 AM
Newbie audio chain question dasfreak Analog Line Level 1 19th September 2010 10:12 AM
DIY build sound better than a good commercial design in a side-by-side comparison? smellygas Multi-Way 66 25th November 2009 08:26 PM
Any recommendations for tube for vari-mu compressor? leadbelly Tubes / Valves 5 8th April 2009 08:23 PM
