Instruments and Amps Everything that makes music, Especially including instrument amps.
Microphone modification help
Old 4th August 2011, 12:43 AM   #1
argonrepublic is offline argonrepublic  Canada
Default Microphone modification help
Would someone please direct me to the components for this modification?
I don't understand all of the locations and the type of components described.
I have removed C9 and C10, I have replaced the tube.
Thanks in advance.
1. Remove C9 and C10 to remove the 25Khz peak resonance in the high end.
2. Change the caps in the signal path: Polystyrene input and 1uF polypropylene output (C8)
3. Change the tube to a 6072 or a very good 12AT7
4. Add a tiny EQ cap like that found in the ELA m251 design, to the output of the 1st stage. I like 200pF myself.
Optional:
5. Change the cathode bypass cap from 100uF to 22uF to reduce low frequency rumble and distortion.
6. Change the cathode bias resistor to 1.8K to increase plate current in both tubes and improve biasing on the 2nd stage.
Old 4th August 2011, 02:01 AM   #2
On Hiatus
SY's Avatar
Schematic, please?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th August 2011, 02:52 AM   #3
I thought I attached. Thanks
Old 4th August 2011, 06:20 AM   #4
revintage is offline revintage
Unreadable, use *.png instead.
Old 4th August 2011, 12:36 PM   #5
OK
Microphone modification helpHide this!Advertise here!
piezo microphone ninna Analogue Source 5 3rd January 2013 02:23 AM
Zoom H2 - Microphone Modification Panasonic WM61A Joe Alesi Everything Else 6 10th October 2011 11:28 PM
microphone VolMax Audio Instruments and Amps 17 20th November 2010 01:33 AM
spy microphone sss Everything Else 10 6th January 2005 11:00 AM
