building New amp building New amp - Page 2 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
building New amp
building New amp
Old 2nd August 2011, 09:37 AM   #11
paku5535 is offline paku5535  India
thanks both of you.
does the quality of amp come from speaker or power section or pre section?
what is the specialty in guitar amp speaker??
for 14 w amp what should be the speaker size and resistance for good bass effect?
can u plz suggest a good solid state based preamp that will close to valve sound.........
for tda2030 what size of heat sink is required?
thanks
Old 2nd August 2011, 02:28 PM   #12
moschfet is offline moschfet  Germany
moschfet's Avatar
The quality should be high at all But the sound is primarily shaped by the preamp, then the speaker and at the end the Poweramp.
12 "are typical of guitar speaker, and they bring enough bass (at least at home). A typical guitar speaker has to 100dB and at 4-5kHz Frequency range an overshoot.
My preamp is not bad, but on runoffgroove.com, there are also nice preamps.
As a heat sink reaches a mounting plate made of aluminum, the housing for example.
Regards http://xipix.de/
Old 2nd August 2011, 04:50 PM   #13
thanks for the reply, there are several projects on the run groove. which one you suggest??
Old 2nd August 2011, 05:13 PM   #14
moschfet's Avatar
The question has to decide your taste.
One of my favorits is BSIAB2 as preamp, for example
Old 2nd August 2011, 06:17 PM   #15
thanks moschfet
Old 4th August 2011, 12:54 PM   #16
Default to moschfet
i have connected my already built preamp to my solid state sub woofer i used to connect my computer. but the sound that is appearing is not that i am looking for. but i am little confused how the tda2030 will sound.
do u have any idea??
Old 4th August 2011, 03:04 PM   #17
moschfet's Avatar
Yes, I can imagine. And that is the reason why guitarists play on guitarspeaker.
This is the circuit with the 'modification' especially for Guitar Amps:
R5 worsens the damping factor of the amplifier. Similar to a tube amp. The rest is wired nearly as in the data sheet.
Old 4th August 2011, 07:46 PM   #18
what do u mean by damping factor??
when i will choose the speaker can i choose any general audio speaker or do i have to choose any special guitar speaker??
good night
Old 4th August 2011, 08:03 PM   #19
Minion is offline Minion  Canada
Half of the reason why a Guitar amp sounds the way it does is because of the speaker ..... Guitar speakers are made to have a certain frequency curve and a frequency range of arround 50hz - 6000hz and to break up early and in a certain way ..... Hi-Fi speakers are made to have a flat frequency responce and a wider frequency range and not break up ...... you will know the difference when you hear it ......
You can get a good 12in guitar speaker for under $100 and for as low as $50 .......
Old 6th August 2011, 10:12 AM   #20
Default hello moschfet
can i use roland cube 30x speaker for my project ??
then do i need different power section??
building New ampHide this!Advertise here!
Amp Design/what goes into building a great amp fglabach Solid State 141 12th June 2009 05:17 PM
building EMG BQS system <>? woodbuilder Instruments and Amps 0 16th May 2008 02:58 PM
Building ONO - looking for 2SK170 & 2SK389 skseah Pass Labs 34 7th February 2005 10:19 PM
Copyright ©1999-2017 diyAudio
