Instruments and Amps Everything that makes music, Especially including instrument amps.
marmac valve head
marmac valve head
Old 24th June 2011, 12:35 AM   #1
cxdavid is offline cxdavid
Default marmac valve head
hi got this the other day its sounds great even though its never had new valves.
gonna put new ones in soon as, its very hissy on the treble, any idea how i might cure this....or has any one else got aany marmac amps of any other info on them. was built in early 70 s in sligo ireland..thanx again cheers
Old 24th June 2011, 01:28 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Looks like a hybrid valve SS amp.
It could be the old style op amps causing the excessive hiss.
Might be worth replacing them with newer op amps.
I used to have a Simms-Watts amp that looked very similar (case wise) and that could really rock when turned up. Despite being 100watts I couldnt stand next to it becasue it was so loud.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 24th June 2011, 08:58 AM   #3
hi thanxs for interest, you are the second person to suggest changing the op amps, so think it could be the thing to do. it currently uses LM741cn which are old. was told to check out LM833, if it uses dual op amps. however i think its not using dual, could ya recomend a replacement......thanxs.
this too is loud and great sound too.
marmac valve headHide this!Advertise here!
dean markley valve head 120 watt mondogenerator Instruments and Amps 19 25th February 2012 07:09 PM
Head to head comparison of Manger and Lowther in Acousta and Front horns David Pinnegar Full Range 3 12th January 2011 01:59 AM
wtd - small HT transformer (valve head amp) UK adamus Swap Meet 0 14th December 2010 07:40 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
motor types head to head for a TT p_ete2003 Analogue Source 20 11th January 2007 09:29 PM
Copyright ©1999-2017 diyAudio
