Instruments and Amps Everything that makes music, Especially including instrument amps.
The Hundred-Buck Amp Challenge
Old 16th July 2011, 09:48 PM   #611
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I am waiting for your Youtube presentations!
I need to make something that works first. Then maybe find a real guitar player for a demo. My left hand has become rather stiff and arthritic, goes numb a lot. Don't play guitar anymore.
5 years ago I could find a dozen good players at work. Most were laid off, and half of the building is now off limits. The metal shreader next door moved away and so did my daughters band mates. That is why I haven't done guitar amps in a long time.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th July 2011, 11:24 PM   #612
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
Originally Posted by TheGimp View Post
Nice cab, but how do you hold the front panel in?
Blind screws extending through the front panel before covering?
Yes.
The idea is tee-nuts inserted into counter-bored recesses before mounting the grille cloth. The speaker mounting screws thread into these as do the front panel mounting screws. The prototype here just uses sheet metal screws...
Old 16th July 2011, 11:52 PM   #613
hunoz is offline hunoz  Australia
Originally Posted by Printer2 View Post
Some owners replace the front baffles of newer amps because they were made from MDF and they feel the sound is too dead. Fender used to have their front baffle of their Tweed amps suspended by four screws, the baffle would continue to vibrate after the note started to decay.
On the topic of vibration and resonances, some acoustic feedback made its way back to the tubes in a combo. Depending on the tube there might be a fine line between enough or too much though.
To my knowledge, these days most factory made cabinets use MDF, chipboard or plywood to keep costs down. Replacing the baffle may improve the sound enough to please given individuals. I see nothing wrong in doing so.
As I said initially, in my experience, if the cabinet is made of cedar or pine then what material was used for the baffle or face will make little difference. Of course if the size of the cabinet and the speaker/s are a mismatch then you will have problems no matter what you use!
We did not talk about it, but woodworking techniques used for building the cabinet will also contribute substantially to the sound. Proper joints and the type of glue used will make a big difference. On the other hand, using screws and/or a loose baffle will degrade the sound!
Old 17th July 2011, 01:18 AM   #614
Printer2 is offline Printer2  Canada
The baffle board is used as a soundboard as much as the sides. How would pine or some other resonant wood not be better than MDF? As far as the loose baffle degrading the sound, that is not necessarily so.
depends on the construction of the cab, but they can influence the sound quite a bit.
If they're hung from the top and bottom and allowed to float free on the sides, then a thinner baffle (say 3/8" in imperial measurements, if I remember correctly) will resonate quite a bit. You have to make sure that the wood is strong and thick enough to hold the speakers without cracking though, so there's a balance to be struck.
OffsetGuitars.com • View topic - Thickness of "floating baffle boards" Fender style???
Both cabs utilize a classic floating baffle design.
Dr. Z Amplification | 2 x 10 Cabinet
Valvetrain Amps
8" Weber Signature Series speaker, 5 watts out of 1 6v6 tube, preamp is 1 12AX7 tube. Tone knob, volume knob, solid pine cabinet with floating baffle.
A quick primer on cabinets by Gibson
http://www.gibson.com/en-us/Lifestyle/Features/Tone Tips_ Speaker Cabinets/
Old 17th July 2011, 01:57 AM   #615
The baffle made out of pine or any resonant wood will be better than the man made materials. I have never said otherwise! However, in my experience it will not make a big difference. In my opinion this is especially true when the cabinet and the baffle are joint using screws rather than being glued together. If and when the cabinet and baffle are large compared to the size of the speaker it will also make more of a difference what materials and construction techniques were used. The speaker you use will be much more of a difference than the type of baffle material!!!
I appreciate you have a different point of view from mine!
If and when the baffle is a floating one, the baffle should be made of resonant wood and the materials used for the cabinet will make less of a difference. Again this is just my opinion. I personally do not like floating baffle for speaker boxes. I have built them, tried them and they are not for me.
Old 17th July 2011, 02:51 AM   #616
Default I don't win - a little over budget
Here's my low cost DIY amp. It did go a little over the $100 budget at $469.66 but I priced in use a lot of parts I already had. It includes a 12" cabinet. I may have spent about $100 in additional parts. The parts are all off the shelf available in small quantities to DIY builders, e.g. uses a Hammond chassis, cover, and cage.
I'm still tweaking the voicing, however it's pretty usable as is. The cabinet is made from 2 layers of 1/2" Russian birch laminated together. The baffle is one thickness but is hardly more than a mounting ring.
The circuit is like the Fender Champ but adapted for the 807. It has a mostly clean tone with a nice smooth crunch coming on when digging in. The distortion comes mostly from the first stage as it's somewhat independent of the volume setting.
Old 17th July 2011, 03:43 AM   #617
Not my cup of tea either, mind you I have heard some Dr Z amps that sound great.
Old 17th July 2011, 05:56 AM   #618
wdcw is offline wdcw  Australia
Gday Guy's,
I've been protyping my 5W amp & tested it just now, still some things to tidy up for the final thing but it comes in at just under $100, $99.65 to be exact.
As you'll see it's not finished but it's close, i'll upload the first sound clip somewhere & post the link.
I called it "The Iron Maiden", its got some balls about it--big sound!
Maybe the Moderator could change something so we can upload MP'3 or something for sound clips--hint hint!
Pictures attached!
Cheers
Old 17th July 2011, 10:58 AM   #619
Sorry for the double post, I just uploaded a sound clip on youtube for the 1st test of the Iron Maiden amp.
It's a bit boring & repetative with me just adjusting the tone controls but here goes, any comments good bad or ugly are welcome.
The amp sounds a little bit brighter in real life, I guess recording into the computer WITHOUT EDITING has some effect.
It's a raw recording.
I forgot to mention, as far as guitar amps go, I think you will find it an original design of mine.
Here's the link:
‪The Iron Maiden‬‏ - YouTube
Cheers
Old 17th July 2011, 12:50 PM   #620
Not bad. Check out how it sounds at the edge of breakup.
The Hundred-Buck Amp ChallengeHide this!Advertise here!
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 12:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 02:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
Copyright ©1999-2017 diyAudio
