Instruments and Amps Everything that makes music, Especially including instrument amps.
The Hundred-Buck Amp Challenge
Old 9th July 2011, 07:06 PM   #511
quikie22 is offline quikie22  Malaysia
completed my BERSIH2.0 based on 6N2P and 6P1P.. Sounds too clean (Bersih means clean in local dialect)...now to start playing with distortion and overdrive... so far total cost of is around 70USD.
Old 9th July 2011, 07:29 PM   #512
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Sounds on different levels of gain. Almost the same loudness, different timbres. Is it good, or too much compression?
YouTube - ‪World Champion guitar amp project -- sounds on different levels of gain‬‏
The Devil is not so terrible as his math model is!
Old 9th July 2011, 07:33 PM   #513
Wavebourn's Avatar
Originally Posted by costis_n View Post
Can you please explain the power supply and output stage, it it too strange looking for my feeble mind... Pretty please?
Preamp and screen grid are powered from a network that supplies more of voltage on low signals, less voltage on high signals. It increases tone dynamics decreasing SPL dynamic.
Old 9th July 2011, 07:50 PM   #514
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Originally Posted by Wavebourn View Post
If you wired ground as drawn on your picture it have to oscillate.
Which wiring? First and second stage B+? They actually have an RC stage between them.
Ground is star connection with common point where B+ enters from HP supply.
Old 9th July 2011, 08:10 PM   #515
Wavebourn's Avatar
What about input and output jacks?
Old 9th July 2011, 08:46 PM   #516
TheGimp's Avatar
Input jack is grounded at the capacitor bank where power comes in.
Output tied to star as well.
All of signal path is single end grounded RG-174/U shielded cable.
Old 9th July 2011, 08:48 PM   #517
Wavebourn's Avatar
Are they both isolated from chassis, or form a loop through it?
By the way, I recorded sound on high pitch strings, to show compression of my amp:
http://www.youtube.com/watch?v=pRF05L9btYM
Old 9th July 2011, 09:17 PM   #518
TheGimp's Avatar
No chassis. This is on a tube-lab type breadboard.
Since there is no global feedback, I've tried removing the ground to the output and letting it float. No change in the oscillation.
I also considered the possibility of feedback between the triode and pentode in the 6GH8A which were stages 1 and 3 which were in phase, so I changed the position of the triodes so that it is 6GH8A Pentode input driving tonestack, 6GH8A Triode second gain stage after tonestack, 6F4P triode 3rd gain stage, other 6F4P triode as Concertina, then the two output 6F4P Pentodes.
The oscillation breaks out at the peak of the signal and is only seen now on the 3rd gain stage through output.
I switched to a 400Hz test tone.
Old 9th July 2011, 09:21 PM   #519
TheGimp's Avatar
At 30 and 31 seconds it sounds like your amp is note switching briefly.
Nice.
Old 9th July 2011, 09:22 PM   #520
Wavebourn's Avatar
Did you try 10k grid stopper for the output tube?
The Hundred-Buck Amp ChallengeHide this!Advertise here!
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 01:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 11:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 07:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 03:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 06:59 PM
Copyright ©1999-2017 diyAudio
