Instruments and Amps Everything that makes music, Especially including instrument amps.
The Hundred-Buck Amp Challenge
Old 7th July 2011, 12:44 PM   #481
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I keep my upper frequency -3dB limit below 10KHz for my guitar amps.
I suggest reducing you coupling cap values.
Old 7th July 2011, 01:26 PM   #482
TheGimp's Avatar
Since the fundimentals are at or below 1Khz, the tenth harmonic will only be at 10KHz, so no sense having a greater bandwidth as it adds to noise.
This was an earlier version.
Old 7th July 2011, 02:20 PM   #483
PB2 is offline PB2  United States
PB2's Avatar
Coupling caps alter the low end and I suggest increasing them to reach the lowest note on a standard tuned 6 string of the low 80s or the low 40s if the plan is for a bass amp. Drop tunings are popular with lead guitar so 60 Hz might be a good compromise. I've simulated several popular guitar amps and most have a LF rolloff at ten Hz that compares to his 100 Hz referring to the curve in post #480.
HF rolloff is usually accomplished in guitar amps with the 68K grid stopper at the input jack forming a LP filter with the first tube's Miller capacitance. All the grid stoppers contribute to the HF rolloff.
Old 7th July 2011, 02:55 PM   #484
TheGimp's Avatar
My bad, sorry about that.
Old 7th July 2011, 06:33 PM   #485
ChrisA is offline ChrisA  United States
It will be interesting to see how people approach the distortion aspect.
I've got mine to the point where one can dial the power from below 0.1W up to 3W with the distortion staying at about the same level, although the noise floor comes up with power.
First is distortion mode at 0.1W, second is same at 3W before clipping and the third is in clean mode at 1W.
What does it SOUND like? Not many people could figure out the sound from your graph. I think it measures the wrong thing
It is hard to be objective when describing sound. So I think it's best to make objective comments about what can and can not be heard. Examples might be
1) "It cleans up to sound like a Fender champ." (This sound, I think is do to the tone stack even if on a Champ the pots are replaced with fixed resistors but the standard TMB stack is still in there)
2) Distorted power chords sound good but triads and other "normal" chords sound like mud. (this is typical of most "rock" type heavy clipping type distortion.)
3) It's "touch sensitive". Force in the pick controls distortion without effecting loudness so much. (I think amps need to compress the dynamics to make this happen but that's just my theory)
4) the bass strings tend to distort before the others. (or vice versa) Or "tone changes as you move up the neck." I've heard it both ways but I think a lot of people wold go for crystal clear highs and a "crunchy" bass. (It has to do with the freq. response of the first gain stage because it is typically the second gain stage that is driven into distortion.)
5) This amp is design to be a clean tube sound and to by very "pedal friendly".
Those are all objective things one could say or not say. None of them are good or bad, just observations
I don't think the spectra of a 1K signal says anything at all about a guitar amp. 1K is not realistic. try a sweep of the four octave sweep from 80Hz up. That is the range that is used. No point is showing those higher harmonics either as a typical guitar speaker has very little output above about 5KHz
There is absolutely no "correct" answer to how a guitar amp should sound. My preference would be for one to go from "Champ-like" clean to a blues-overdriven sound and use pedals for anything else. In an ultra low power $100 amp I'd also want it to be a combo.
Old 7th July 2011, 08:58 PM   #486
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I am going to record some video to show how it works.
Also, I will bring some on BAF in San Francisco. We may need some room for guitar amps, I believe.
Also, I have unfinished bass guitar prototype, but I don't have bass guitar. Anyone?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 8th July 2011, 01:49 AM   #487
Trout is offline Trout  United States
Trout's Avatar
Bass? Man, mine has been in the case under my bed for at least 7 years now, think I should get new strings?
Old 8th July 2011, 01:56 AM   #488
Trout's Avatar
Since we are on guitar amps,
Does anyone have a copy of the schematics to mod a Gibson GA-5 to the spec as seen in this video?
3:00 minutes in
Viddler.com - Back to the Future Opening Scene - Uploaded by heyuguys
Old 8th July 2011, 02:06 AM   #489
Wavebourn's Avatar
You have to!
I took my Ibanez from closet where it was standing last 5 years...
Meanwhile, I created Youtube account, uploading movies there. The first one shows parts, the second one oscilloscope screen and sounds. It is a dirty compressor; you can play from clean to super-dirty without touching any knob, on almost the same SPL.
However, I'm not a guitarist, but I played good enough to show how the amp works.
Old 8th July 2011, 03:42 AM   #490
wdcw is offline wdcw  Australia
Gday Wavebourn,
Do you have a link to your Youtube videos?
Cheers
The Hundred-Buck Amp ChallengeHide this!Advertise here!
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 12:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 02:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
