The Hundred-Buck Amp Challenge The Hundred-Buck Amp Challenge - Page 144 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 5th April 2012, 03:09 AM   #1431
Cassiel is offline Cassiel  Libya
OK, here's my stuff. Power supply schematic is not ready yet. The audio file is just a guitar, an amp, a micro and a computer. No editing apart from crude copy and paste. I start clean, then crunchy and then volume goes to 12.
http://www.fileden.com/files/2012/4/...king%20off.wav
More details about the amp with my next post, probably power supply schematic too. This is a lot of work. Both are the same schematic, just choose your fav color (lol).
Old 5th April 2012, 03:47 AM   #1432
benb is offline benb  United States
I see your first cathode resistor says it's 1500k - obviously you meant this to be 1.5k or 1500.
Old 5th April 2012, 04:06 AM   #1433
Printer2 is offline Printer2  Canada
Spent some time and worked out how to add a floating paraphase PI to the 4 pole switch PI I posted. So a simple four pole three position switch will work (hopefully). I lifted a preamp from the guys at Watkins since I just got the tube in the mail and I want to try out the 25L6 tubes I have. The power supply still has to be worked out, just put some parts in place for the heck of it.
Old 5th April 2012, 04:29 AM   #1434
tubekit is offline tubekit  United States
Anyhow you got 100 dollars worth of parts waiting for you. You just have to send an email.
If I may ask, to what specifically does the above quote refer?
Old 5th April 2012, 11:08 AM   #1435
Good luck!
Thanks Wavebourn, I didn't electrocute myself yet. So far luck is on my side.
Yes, 1.5K. Big blunder.
Read post 1403. Hey you're on the list!
Old 6th April 2012, 05:57 PM   #1436
jazbo8 is offline jazbo8
jazbo8's Avatar
Ah, great men think alike, here is Merlin's version (via AX84):
Jaz
Old 7th April 2012, 10:27 PM   #1437
great men
Where to?
Power supply is here! I knew you guys couldn't wait so.......
Three more facts:
1. Power supply caps come from a dead PS, a dead CFL and the poly one is made here in Madrid. Proud of being crap, she is.
2. I did use my cheapest speaker for recording. Remember set up is under 100 dolla (guitar not included). It's a Celestion 12, can't remember its name...RockJunior or something. Ported cabinet.
3. Output transformer comes from a single ended radio. It has several primaries (0, 800, 1.6K, 3.2K) Center tap is 1.6K, serious mismatch in resistance, still, I don't pay the hum penalty.
That's all folks.
Old 7th April 2012, 10:28 PM   #1438
Jaz
That's what first got me started on it. When I first started drawing things up I could not find the link to the picture and just took a few Fender schematics and started from scratch. Ended up being pretty close to Merlin's schematic. What I tried to change was not having the triodes paralleled up in Cathodyne. In this circuit you need an added triode to get the gain back where it should be. I thought you should be able to do it with the two triodes. I posted at AX84 to see if any were still interested in the switched PI thing and had no replies so I went at it on my own.
I am starting on the last circuit I posted, did a half *** board layout on my favorite (strip board), the software I used does not allow to rotate the direction of the strips, not a big deal. This is just the power amp section, I will have to adjust for part size, just gives me a rough guide. Changed some part values, will change some more when it gets up and running. Schematic should not have the grid resistors on the power tubes going to ground, added the fixed bias switch at the last minute and should have deleted the ground. The top strip is the power, the bottom is mainly ground. The black lines are jumpers and a length of holes next to the HV and ground is cut.
Old 11th April 2012, 11:44 PM   #1439
Alvis is offline Alvis
Banned
Nice to hear a sound clip Cassiel.
Old 12th April 2012, 01:51 AM   #1440
Default Happy news. Cool!
Thank you Cassiel.
I sent a letter to Santa Claus.
The Hundred-Buck Amp ChallengeHide this!Advertise here!
Hafler Five Hundred problem hatrack71 Solid State 4 10th June 2009 12:38 PM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
a hundred questions from a noob zoobie Solid State 5 31st May 2003 02:04 PM
Nineteen Hundred Ninety Nine Posts And Counting ;-)... mrfeedback Everything Else 12 21st May 2003 05:59 PM
Copyright ©1999-2017 diyAudio
