Instruments and Amps Everything that makes music, Especially including instrument amps.
Adapter with amp and mp3 input to headphones
Old 11th June 2011, 02:05 AM   #1
RussVT is offline RussVT  United States
Default Adapter with amp and mp3 input to headphones
I am looking for information on how to put together an adapter that has inputs for my amp, and an mp3 player then an output for my headphones. Could I just wire them together or do I need to put something like a diode in between to keep feed back out of the system. Ideally I want to have seperate volume controls for the inputs. I want to be able to play my guitar to music without disturbing my family. Any info woudl be appreciated.
Old 11th June 2011, 02:44 PM   #2
Nigel Goodwin is offline Nigel Goodwin  England
You just need a simple two input stereo mixer, and if it's a passive guitar one of them needs to be a high impedance mono input for the guitar.
Nigel Goodwin
Old 11th June 2011, 03:39 PM   #3
Yeah, that is what I'm trying to get away from. A two input mixer costs money, I have lots of extra cables and parts, I just want to put something together. The input from the guitar will be out of the headphone jack of the amp, so I will not need a high impedance input for the guitar. Thanks for the input though.
Old 11th June 2011, 05:37 PM   #4
sofaspud is offline sofaspud  United States
sofaspud's Avatar
You could try a passive mixer using resistors and potentiometers, but I'm not sure how well it would work. The first circuit on this page shows the idea. You can add 1k-ohm rheostats for volume control.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 14th June 2011, 08:47 AM   #5
Not if you build it yourself, I built one to do an 'emergency' disco one night - a double opamp, couple of stereo pots, eight resistors, eight capacitors, and a 9V battery. It wasn't 'pretty', but I designed and built it in about 30 minutes
It worked perfectly - opamp mixers are really easy devices to build.
Nigel Goodwin
Adapter with amp and mp3 input to headphonesHide this!Advertise here!
XLR balanced to camcorder input adapter yesiam Solid State 0 13th April 2011 10:25 PM
using an impedance adapter to make an external DAC drive 32Ω headphones? leeperry Headphone Systems 28 28th April 2010 01:05 AM
Headphone Guitar amp with mp3 input jman 31 Chip Amps 45 21st March 2010 08:04 PM
headphones and cd/mp3 walkman gigatron Digital Source 7 27th January 2004 03:51 AM
