Instruments and Amps Everything that makes music, Especially including instrument amps.
Marshall amp is being quiet
Old 17th April 2011, 04:17 AM   #1
stolenband is offline stolenband  United States
Question Marshall amp is being quiet
Hey guys. Got something for you all.
I just got a marshall bass 12 amp from a goodwill for 25.00 dollars. And it is being quiet. It is not even competing with an acoustic. Is there anything that i need to check on it?? it does also have a gain nob that must be on 4 for it to work. anyone have any fixes?? I want to use the amp, but it is not working for me. Thanks. its hard to find anything on the net.
Old 17th April 2011, 05:23 AM   #2
geraldfryjr is offline geraldfryjr  United States
WHAT IS THE MODEL NUMBER?
Old 17th April 2011, 05:25 AM   #3
t27329 I think. That is what is stamped to the front
Old 17th April 2011, 11:12 AM   #4
Nigel Goodwin is offline Nigel Goodwin  England
That doesn't sound like a Marshall number?, try looking on the back.
Nigel Goodwin
Old 17th April 2011, 01:07 PM   #5
teemuk is offline teemuk  Finland
I think the only Marshall Bass 12 would be 5501.
Plenty, for starters:
- Contact intermittency? / condition of solder joints
- Potentiometer / jack corrosion and overall condition, use some contact cleaner
- Output transistors ok?
If these don't help start tracing signal from input towards output and see what stage fails to amplify or what stage causes too much attenuation.
Old 17th April 2011, 09:33 PM   #6
Here is the schematic. jer
Need schematics: Marshall 5501 Bass 12-amplifier - TalkBass Forums
Old 7th February 2015, 03:49 AM   #7
Sdrapak is offline Sdrapak  Canada
Default Re: Marshall 12" Amp Too Quiet
A very late response, I had this issue with my old Marshall 12" amp, it turned out to be the potentiometer for the Volume was dirty after no use for years, fiddling with the knob for a few minutes brought back a bit of life to the point where I knew that was the issue, but disassembling the box and getting at the back of the potentiometer and spraying it with contact cleaner or replacing it is the only real solution.
Old 7th February 2015, 04:05 PM   #8
boobtube is offline boobtube  United States
Is the sound distorted or just clean and quiet? Blown speaker?
Marshall amp is being quietHide this!Advertise here!
Quiet 12V cooling fan for pro amp (24V supply)? Evenharmonics Solid State 7 10th January 2011 02:02 PM
LM3876 chip amp very quiet and distorted... jdsnape Chip Amps 2 27th November 2009 08:11 PM
Mesa Boogie bass amp quiet mekaiver Instruments and Amps 15 12th July 2009 05:56 PM
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
Help! Marshal MG50DFX Anybody Anyideas thomas7037 Solid State 1 11th August 2005 02:29 AM
Copyright ©1999-2017 diyAudio
