Instruments and Amps Everything that makes music, Especially including instrument amps.
Marshall Amp Biasing
Old 14th April 2011, 05:57 PM   #1
TubeManiac is offline TubeManiac  Netherlands
Default Marshall Amp Biasing
I have a Amp from a friend who is broken. And want to fix it.
But only have one question about biasing.
Where and how and how much do i need to measure for biasing ?
Old 14th April 2011, 07:16 PM   #2
MattyAve is offline MattyAve  United States
What exactly is wrong with the amp to begin with?
Old 15th April 2011, 08:44 PM   #3
one of the powertubes was broken.
But i don't know how to bias it.
Old 15th April 2011, 10:51 PM   #4
Pins 1&8 of the tube socket should be tied to ground by a metal wire.
Remove it.
Install 1 ohm resistor from pins 1&8 to ground. (1/4 watt)
Measuring the voltage across this new resistor gives you current through the tube.
Example: 1mv = 1ma
Set it for 25mv.
Do this for all output tube sockets.
Old 15th April 2011, 11:46 PM   #5
scott17 is offline scott17
You might want to check out this site for a more in depth discussion of the whys and hows of biasing. The website is a little out there but the info is great: Tales From The Tone Lounge; Biasing a Marshall JCM800!
Old 16th April 2011, 12:22 AM   #6
indianajo is offline indianajo  United States
indianajo's Avatar
read the tone lounge article. There is no way I am going to use my 350 V rated scope probes (Smith OP2010) to measure plate current. My question is, my dynakit ST70 manual recommends bias for the 6CA7's at 100 ma cathode current, 50 ma x 2. My tubes wear out in about 8 years of 6 hours a day. Tone Lounge is recommending 36 ma plate current. MattyAve is recommending 25 ma. The EL34 is supposed to be interchangeable with the EL34. Why the difference?
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 16th April 2011, 04:24 AM   #7
dcgillespie is offline dcgillespie  United States
25 ma may be good to your tubes, but it is guaranteed to develop major cross-over distortion as well. Even guitarists don't like that kind of distortion. For the typical B+ I've seen Marshall use in a 1987 (~485 vdc), the output tubes should be biased at about 45 ma each, which will still be plenty kind to the tubes, and keep them clear of the notch distortion excessively low quiescent current operation causes.
Dave
Old 16th April 2011, 05:41 PM   #8
indianajo's Avatar
Dave
Thanks doggillespie. Watts matter tone lounge said, 485Vx45ma is probably the same watts as 405Vx50ma I am using. Didn't know the Marshall had such elevated plate voltage.
Old 18th April 2011, 08:11 PM   #9
Thanks guys !! Going to fit those resistors at the cathode and trying to bias them to about 45-50mA
Old 26th April 2011, 01:46 PM   #10
eggontoast is offline eggontoast  England
Current factory bias spec for a 1987 is 42mA
Marshall Amp BiasingHide this!Advertise here!
Marshall Amp strange wiring voivodata Instruments and Amps 7 17th November 2010 02:27 AM
Marshall amp driver overheating Rotus623 Instruments and Amps 7 5th October 2010 01:19 PM
Biasing amp leander Solid State 19 26th October 2005 01:57 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 05:45 AM
Copyright ©1999-2017 diyAudio
