Instruments and Amps Everything that makes music, Especially including instrument amps.
Fender 5F1 Champ clone with triode mode
Old 1st April 2011, 06:01 PM   #11
zarniwoop is offline zarniwoop  United States
Originally Posted by scitizen17 View Post
There is no "sag" in a class A amp like the 5F1, so I don't see that choke, or no choke, makes any difference whatsoever except to provide better filtering and therefore better noise reduction. Switches fail over time when not used properly, so I don't see that as a factor.
The current of a class A amp is mostly constant as long as you are well away from maximum output. In a champ things getting crazy as you play and overload the amp on peaks; class A goes out the window. There will be huge amount of sag on the psu and any increase in DCR will magnify it. BTW, make sure you have a decently sized (value and rating) screen stopper resisitor on the 6V6. I have watched the screens light-up with heat up as the ouput stage starts overloading.
Old 1st April 2011, 08:33 PM   #12
scott17 is offline scott17
Right now I have a 100 ohm, 3 Watt on the screen. The choke in the PS is 411 ohms. I'd like to put a scope on the amp and see just what happens during overload. I'm playing a 1998 G&L Legacy, but I haven't been able to play the amp much, hopefully this weekend. I built a Gilmore Jr., actually 2 Gilmore Jrs. in the same chassis, about 3 years ago. Based on my initial impressions of the Champ clone, I'm really liking it.
Fender 5F1 Champ clone with triode modeHide this!Advertise here!
Fender champ circuit low output. Jayoldstuff Instruments and Amps 6 27th March 2011 07:58 PM
Fender Champ 5C1 help needed! Spasticteapot Instruments and Amps 12 27th July 2010 11:45 PM
Fender Footswitch (Champ 25 se) R_Atkinson Vendor's Bazaar 0 9th May 2007 10:04 PM
Fender princeton/champ clone layt Instruments and Amps 6 24th April 2005 06:47 AM
Fender Champ: What Transformers? edsmith Instruments and Amps 2 6th August 2004 12:14 PM
Copyright ©1999-2017 diyAudio
