Instruments and Amps Everything that makes music, Especially including instrument amps.
Mellotron preamp schematic
Old 1st September 2011, 10:46 AM   #131
geraldfryjr is offline geraldfryjr  United States
It has been a while since I have seen this thread and I am glad to see you have made some progress by swapping to a lower noise transistor.
I had excpected the opamp circuit to be a little brighter sounding according to the sims.
It is very diffucult to tune it in the simulation with out knowing the actual tape head systems charicteristics,But was a good try for a basis to start on.
I still have the files if you would like me to try any other component changes sometime.
Otherwise for it sounding to bright how did it work out in the noise department vs gain ?
And which opamp did you end up using?
jer
Old 6th September 2011, 05:18 PM   #132
atmasphere is offline atmasphere  United States
atmasphere's Avatar
I used a fairly basic opamp, the TL082. If I could work out the EQ I think the noise would be fine.
Basically how this circuit behaved was that there was a rising response rather than a falling response at high frequencies.
The Mellotron has a second amp board which is the line amplifier. It strikes me that if I allowed for a circuit board that is the same size as both boards in the Mellotron, that a single opamp could do all the EQ/amp chores.
The sound of the instrument has more to do with the tapes than it does with the electronics so this might not be a bad move...
Old 7th September 2011, 11:43 AM   #133
Can you post a schematic of the circuit that you have come up with?
I you are using the TL082 you can use the second half as a buffer and attenuate the highs abit as well I think that I had mentioned this in an earlier post.
jer
Old 9th September 2011, 04:37 PM   #134
atmasphere's Avatar
So far its just the circuit that you modeled earlier. The Mellotron has a very basic tone control to roll the highs- normally its turned all the way up.
Old 11th September 2011, 06:46 AM   #135
Okay Cool !!! I will do some searching for a suitible EQ'ing circuit for you.
jer
Mellotron preamp schematicHide this!Advertise here!
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted tiefbassuebertr Analogue Source 41 13th February 2016 05:51 PM
Preamp schematic. beppe61 Solid State 49 23rd December 2015 08:16 PM
Need help: Looking for ECF80 preamp schematic Mrpong Tubes / Valves 1 21st March 2007 02:22 AM
Trying to understand preamp schematic... Saurav Tubes / Valves 31 26th October 2006 02:27 PM
Preamp schematic... Guiness Tubes / Valves 17 12th February 2004 02:37 PM
