Instruments and Amps Everything that makes music, Especially including instrument amps.
Orange Bass Terror 500 question..
Old 23rd March 2011, 12:33 PM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default Orange Bass Terror 500 question..
Hi everybody..
I have a question for my brother..
Recently he ordered a Orange Bass Terror 500 amplifier from USA.. Naturally they shipped a 110v mains model while we use 220v mains in Turkey.. But my bro has NO electric knowledge and he cannot guess that situation before purchasing..
Anyway,
Now we have a 110v amplifier and there is no chance to change it. However as I examined Orange BT500 owners manual, it has a switch or jumper in its power supply for 110-220 selection. But I couldnt find it after a quick inspection inside of it. I saw just a jumper with a 110-115v notification (as you can see the bottom)..
Do you think its for 110-220 selection and it will be work in 220 after cutting this jumper?
Or anyone know something about that amplifier?
Every kind of information will be good for me..
Thanks in advance..
Best regards,
Ozgur
Old 23rd March 2011, 12:55 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Have you contacted the manufacturer?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 23rd March 2011, 01:00 PM   #3
Dxvideo's Avatar
Not yet. But in their (offical) forum I saw a topic about the same problem from Norway... And their answer is "why did'nt you buy it from our distributor in Sweden?"... Nice customer care
So it will be useless I think..
Best regards,
Ozgur
Old 23rd March 2011, 01:46 PM   #4
chris661 is offline chris661  United Kingdom
chris661's Avatar
With a bit of luck, they'll've used a centre-tapped primary.
If they have, you can connect 230v across both windings, instead of 115v across one.
Chris
My work: www.grimshawaudio.com
Old 23rd March 2011, 01:57 PM   #5
Dxvideo's Avatar
I am an unlucky man friend!
They use SMPS and not transformer..
Best regards,
Ozgur
Old 23rd March 2011, 03:29 PM   #6
godfrey is offline godfrey  South Africa
According to this pic in the owner's manual, you close the switch for 110V, and open the switch for 220V. I'd guess you were right in post 1: with a jumper instead of a switch, you remove/cut the jumper for 220V.
You'll need to use a smaller fuse for 220V, and a much smaller one the first time you power up in case that was a bad guess about the jumper.
Old 23rd March 2011, 03:33 PM   #7
Dxvideo's Avatar
You must be right... However it would be an expensive experiment!
I'll try it with a lower value fuse or a 60w lamp may be!
I'll report you about the result...
Best regards,
Ozgur
Old 23rd March 2011, 04:26 PM   #8
Can't you open it and see what the jumper's connected to?
Old 23rd March 2011, 04:32 PM   #9
Dxvideo's Avatar
Thats a good idea but my brother is ~800km away from here. And I'll help him via telephone while he's cutting the wire.. And if you consider he's an ignorant about the electronics its very hard to tell him to inspect the connections... As I said, he will cut the wire and put a series 60w lamp to the power line then try it. You dont believe if I tell how hard to tell him just these..
Best regards,
Ozgur
Orange Bass Terror 500 question..Hide this!Advertise here!
Trace Elliot AH 500-12 bass amplifier elec972 Instruments and Amps 24 5th February 2013 03:46 PM
Orange Tiny Terror with Kenwood 15" speaker tuanuibi Instruments and Amps 12 23rd December 2011 12:05 PM
American Bass VFL-500.1 mike49504 Car Audio 5 8th January 2011 12:07 AM
Orange Squeezer - compressor for bass bentson Instruments and Amps 4 21st June 2007 09:57 AM
Best bass horn 50 500 Hz rick57 Multi-Way 37 6th March 2005 10:38 PM
Copyright ©1999-2017 diyAudio
