Instruments and Amps Everything that makes music, Especially including instrument amps.
1964 Amplifier!!
1964 Amplifier!!
Old 8th January 2011, 02:26 AM   #1
Rotus623 is offline Rotus623  United States
Default 1964 Amplifier!!
I just picked up a super-clean 1964 Sano Supersonic amplifier!! The tone out of this amp is sweeeeettttt!It takes my OD pedal so nicely. The power tubes are 8417's. Hope I don't have to replace those anytime soon $$$$$$$$$$. Just thought you guys might be interested!!
Old 8th January 2011, 02:47 AM   #2
Pano is offline Pano  United States
Pano's Avatar
1964 Amplifier!!
That thing even looks loud!
Old 8th January 2011, 03:05 AM   #3
klm1 is offline klm1  United States
klm1's Avatar
Default Sweeeettt!
that's 100W tube power in a push-pull config; it IS loudness...
AES shows out of stock on 8417's, I'd re-bias lower, if I were you...
some like it hot;"the biggest mistakes are made by those who make assumptions!" Graham Maynard
Old 8th January 2011, 03:45 AM   #4
Yeah KLM one, I know what you re saying bro. Turn it down and conserve on the tubes. Tube depot has the 8417's for 70.00 each. Not too bad. Plus I dont want to add a bias pot to this classic. The only problem that I have with it is that the 15" is not stock, and the dB level is higher than the 8" speakers.
Old 8th January 2011, 03:46 AM   #5
Pano, it's loud man. My ears are ringing right now actually.
Old 8th January 2011, 04:10 AM   #6
Rockmore is offline Rockmore  United States
Rockmore's Avatar
All I can say is, Rock 'N Roll!
Go through it with a fine tooth comb for common-sense stuff in your look-see. Fix anything easy and common first. Crank it buddy. Old school STILL rocks.
Old 8th January 2011, 05:48 AM   #7
danFrank is offline danFrank  United States
1964 Amplifier!!
If you have to get new 8417 tubes DO NOT get the GE branded ones as they had lots of problems with thermal runaway. IIRC the Sylvania ones are the good ones.
You can replace with 6550's but you will probably have to add another gain stage or up the gain on one of the existing stages as the 8417 needs about half the drive of a 6550.
I would also replace power supply / electrolytic capacitors as the originals are probably bad and have become leaky.
Good luck.... Daniel
Old 8th January 2011, 02:20 PM   #8
Thanks for the advice Dan. The tubes that are in here are the Sylvania ones. They look like they have lots of life left. I hear the 8417's are long-lived.
Old 8th January 2011, 02:38 PM   #9
kevinkr's Avatar
1964 Amplifier!!
Still, I'd grab some 8417 while the grabbing is good. I'm not sure who else made the 8417, but IMVLE the Sylvania seemed rugged. There really isn't a great sub for this tube either so get some now. Yep, I know I sound redundant.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 8th January 2011, 03:16 PM   #10
Thanks, thats actually good advice. Those tubes cost 75.00 each, so I am only going to get one set. : )
1964 Amplifier!!Hide this!Advertise here!
Wanted: Schematic and information for Harman Kardon Citation B from 1963 or 1964 tiefbassuebertr Solid State 22 19th June 2016 05:54 PM
FS: NOS RCA 6AS7G (1964) texaslonghorn Swap Meet 0 29th October 2010 11:47 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2017 diyAudio
