Instruments and Amps Everything that makes music, Especially including instrument amps.
help for a tube distortor
Old 11th December 2010, 07:12 PM   #11
Minion is offline Minion  Canada
Originally Posted by Peckerwood View Post
Minion, are you saying that he won't get nice distortion because he is using a 12AX7? Or because he is running it at 12 volts?
You get great distortion out of a 12ax7 but is sounds pretty farty at 12v , there isn"t enough headroom at 12v for the amount of gain in at 12ax7 , I second the suggestion to try a 12au7 at 12v as it has less gain and would need less headroom .....
Old 14th December 2010, 10:48 AM   #12
Peckerwood is offline Peckerwood  United States
Peckerwood's Avatar
I have a pre-CBS Fender Bassman amp (lousy bass amp but a good guitar amp) and it has 12 A something besides X 7s. It might be 12 AU7s. It does have less gain than all my other amps and they all have 12 AX7s.
help for a tube distortorHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
6n6p tube as output tube for small guitar amp moonbird Instruments and Amps 28 7th September 2011 04:28 AM
can't find valve art tube - and glowey tube pic wicked1 Tubes / Valves 23 10th February 2009 12:54 AM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
