Instruments and Amps Everything that makes music, Especially including instrument amps.
Using an existing ported enclosure
Old 22nd August 2010, 12:12 PM   #1
5u4 is offline 5u4  United States
5u4's Avatar
Default Using an existing ported enclosure
I'm using an existing bass reflex? box with 1.28 cu ft ID & a 5.6" dia hole cut the .5" thick front baffle. Using a WGS Veteran 10" (20W) I'm using this for electric guitar which is a full sounding combination. Wondering if someone could calculate the frequency response, etc. or maybe point me to a program that will. Thanks.
WGS Veteran 10" specifications:
Fs 97 hz
Re 6.7 Ohm
Le .30mH
Qms 15.18
Qes 1.51
Qts 1.38
Vas 1.29 cu ft
Cms .19 mm/N
BL 6.15 T-M
Mms 13.96 grams
Sd 36.61 cu cm
Spl 95 db
Old 23rd August 2010, 03:00 AM   #2
PeteMcK is offline PeteMcK
Here's what Unibox gives me:
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 23rd August 2010, 08:13 PM   #3
5u4's Avatar
Thanks, this seems to be about what I'm hearing, a lower mid boost that sounds good as a guitar cab.
Using an existing ported enclosureHide this!Advertise here!
Working with existing Sub enclosure Donovad Subwoofers 1 18th November 2008 06:27 PM
Ported Enclosure Advice JakeDN Subwoofers 36 22nd April 2008 09:24 PM
HELP with driver selection for existing enclosure fazman Multi-Way 4 26th October 2007 02:24 PM
Ported enclosure question MrPerfectionest Car Audio 5 31st October 2006 04:08 PM
Tempest Ported Enclosure SsZERO Subwoofers 12 11th March 2002 06:50 AM
