Instruments and Amps Everything that makes music, Especially including instrument amps.
Post your Musical Instruments here.
Old 6th January 2013, 11:38 AM   #151
JRGuitarGuy is offline JRGuitarGuy
Banned
Yeah I liked both but I just didn't like how when out of phase it was noticeable bass decrease and excessive highs but there was a different mid range character not sure if it was bad or good just different kinda hard to describe
in phase the mids were more snappy out of phase it was more like smeared/smudged mids if that makes any sense lol
Sylvania 6v6 - YouTube
Lynch infused with VH and infused with something else that I don't know lol yeah I'm pretty crazy haha
the cab is in phase in that video though lol
just hoping these screens are not gonna blow up anytime soon lol
I had the Dimebucker in my Ibanez JS1000 too lol sure satch would love that rofl, I still got the fred though Ill keep it I like it clean has nice twang hell might put it in neck but really think I need a super D, or tonezone, dimebucker is just hot as hell but ceramic magnets just don't have the warmth I like and it is bit trebly/spikey lol but it does have that searing/molten hell tone under gain lol
Old 30th January 2013, 03:45 AM   #152
Printer2 is offline Printer2  Canada
It is almost like I gave up amp building, pretty much did while learning how to make this thing. Far from perfect but good enough for a first try.
Old 30th January 2013, 05:54 PM   #153
marvinkite is offline marvinkite
Default NICE!
So, I'm thinking...acoustic in an electric shape? Are you going to put electronics in it? How does it sund and play??
Old 30th January 2013, 06:05 PM   #154
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Wow! I'd say a lot better than "good enough".
jeff
Old 30th January 2013, 06:14 PM   #155
Banned
modesty is a good thing. xD
Old 1st February 2013, 01:05 AM   #156
Well because it was an experiment I did not go all out on it. I glued together some 1" x 2" poplar pieces to make the neck as I did not want to waste any better wood. The body was made out of six pieces of pine and the weather was changing so I glued them all up at the same time and I ended up with a glue line on the back. The neck feels great and I did a real good job on getting it smooth and straight, then screwed up the fret job by using wire that was 0.002" wider than the slot the fret saw cut. I never knew fret wire came in different sizes. Installing them distorted the metal and I had to sand the frets down quite a bit to get them level. I was worried the string tension on the top and left the bracing a little heavier than needed. The finish is not factory perfect.
That being said unless you are really looking hard you would not notice the flaws. The bridge still needs to be experimented with and down the line I might even make one with a piezo in it and was thinking of a floating magnetic pickup at the neck. I have electric strings on it now and it does sound bright, not that there would be thunderous bass from a guitar with this thin a body. It is three inches thick, the reason I did this design is the smaller volume required a smaller sound hole and I thought a small hole in the traditional location would look bad. I want to try it with acoustic strings yet. It sounds fairly guitar like up to the 12th fret but above it does not ring out as much as it should, it seems to get dampened down quicker than it should. Also there is a bit of sympathetic ringing from the other strings that are not being played. I think a regular bridge may have worked better, maybe for the next one.
Oh yeah, maple fretboard, pine body that was routered out, pine top, red oak veneer on the headstock. A few other pictures.
Old 1st February 2013, 05:33 AM   #157
Default NICE JOB!
Nice attention to wood finishing detail. Nice smooth fretting...mine is not that good (luckily I made my fretboard removable). I see you made the saddle out of what looks like fret wire. Interesting. I wouldn't expect it would have deep tone at just three inches deep, but it probably has good character. Your wood working skills are right up there I would say. Great pics! Thanks for sharing.
Old 11th February 2013, 07:35 PM   #158
robrob is offline robrob  United States
Here's my heavily modified Fender Modern Player Telecaster Plus. The volume pot is about the only original electronic part.
http://robrobinette.com/images/Guitar/Finished4.jpg
I'm here mostly to learn to modify my VHT Special 6 Ultra tube amp.
Old 11th February 2013, 10:27 PM   #159
Here's the second image I tried to post above.
With the 5-way selector, series/split/parallel switch for the bridge humbucker and tone pot push-pull "neck on" mod the guitar has 16 different pickup combinations on tap.
The details of the mods can be found here: Telecaster Mods
Old 12th February 2013, 01:13 AM   #160
I love that color.
Post your Musical Instruments here.Hide this!Advertise here!
Signals from musical instruments in time domain PMA Everything Else 41 27th November 2007 09:31 AM
Aussie musical instruments technology - the didgeridoo jackinnj Instruments and Amps 0 12th July 2005 01:35 AM
ICE/ class d amps used for PA/musical instruments? knutinh Class D 76 24th March 2005 04:49 PM
Musical instruments and equipment one_happy_hippy Swap Meet 0 10th August 2004 04:21 PM
Call for Musical Instruments forum board bob4 Instruments and Amps 41 22nd November 2002 09:36 PM
Copyright ©1999-2017 diyAudio
