Instruments and Amps Everything that makes music, Especially including instrument amps.
high power output instrument amp
Old 24th May 2003, 01:14 PM   #1
fezz is offline fezz  United Kingdom
Default high power output instrument amp
i am considering building a few amplfiers, one to amplify my electronic drum kit, because of the wide frequency range required i cannot use a guitar amp, and am considering basing it uppon a hi-fi amp of around 100W
there are many amps on the internet that are this power, but i would like a relativly easy amp to build so require either a very basic circuit to use or a pcb layout already made.
and no - im not using a chip for this amp - it takes the fun out of it - i will consider both ss or valve
Old 25th May 2003, 07:31 PM   #2
i decided to try and build this amp: http://sound.westhost.com/project3a.htm on strip board, at the moment i hade done most things apprt from the output transistors and the variable resistor and long with a few capacitors as i dont have them at the moment (and the output transistors will be mounted off board)
i hope the picture works
Old 9th July 2003, 05:44 AM   #3
TucsonSean is offline TucsonSean  United States
Default High Power Instrument Amp
Hello fez,
Have you finished your project yet? I have a design that I am working on that may be of interest to you. Check out the following link and look for the zip file:
.http://www.diyaudio.com/forums/showt...threadid=13792
I have finished the PCB layout and am in the process of getting the boards made. When they are tested out properly I will post the gerber files and the updated schematic. There are only minor changes that have been made to the schematic.
An object at rest, cannot be stopped!
Old 14th September 2003, 09:56 AM   #4
im afraid that amplfier is still in the state i posted here as i have decided to build a bridges and parralleled version of the gainclone. should do about 250W into 8Ohm and 350 into 4Ohm
high power output instrument ampHide this!Advertise here!
Which high power CCS for output stage? andyjevans Tubes / Valves 25 4th May 2017 05:28 AM
Favorite High Power Output Transistor mashaffer Solid State 520 21st July 2010 12:52 PM
High output impedance amplifier power 454Casull Solid State 6 13th February 2005 08:25 PM
High Power - Output transformer h_andree Chip Amps 8 2nd March 2004 05:45 PM
Copyright ©1999-2017 diyAudio
