Instruments and Amps Everything that makes music, Especially including instrument amps.
Class D kits for bass guitar amp??
Old 24th February 2010, 03:25 PM   #21
AP2 is offline AP2  Italy
Banned
ok, there is no psu switch for esoteric use of amplifier, then we must convince ourselves that the amplifier can corregir the PSU.
now there a PSU for esoteric use.
stabilized with 150ns response time, free IMD Vs. amplifier,no ripple (zero) at 600w (4R).
excellent power factory.
ultra compact,no big capacitors use.
2 years of development, custom trafo, development a complex asic for running this new architecture "RIPS".
not competitive? ...I think that is unique in the world at the moment
Old 24th February 2010, 05:52 PM   #22
Banned
I think this pic is clearer, has more info for this new amplifier.
Old 25th February 2010, 05:22 AM   #23
Jan-Peter is offline Jan-Peter  Netherlands
Hi AP2,
You are very much enthusiastic about this product, are you the developer or do you have any other (commercial?) direct relation with the manufacture?
Old 25th February 2010, 06:22 AM   #24
Banned
Hi Jean-Peter,
is normal that are taken from a lot of enthusiasm.
developing new real amplifier (research to eliminate certain defects of all Class D amplifier)
no classic schematics and not typical chip Class D use.
this amplifier is not recognized as a big mospower class AB in an anechoic chamber by audiophiles (cd player direct connected). this is the greatest satisfaction for the immense work that was done by the team.
PSU.
research for this new architecture (2 years) solves some problems on Avionics parts.
this alone could justify the investment.
I am an engineer (physical electronics) and am part of the MDI team.
when the commercial side is much contention as you can well imagine.
But .. why do you ask? You are Hypex man, the market is free, everyone has their own products.
You would have the same enthusiasm?
Old 25th February 2010, 06:38 AM   #25
phase_accurate is offline phase_accurate
If the module shown (with PSU included) is the one that will be available around 300 Euros then the price IS competitive - OK.
Regarding PSU ripple compensation: Good ripple compensation is intrinsic to self oscillating class-d amps.
With carrier-based amps one soution is to amplitude-modulate the triangular carrier as a function of PSU voltage. Don't know how old this idea already is at the moment - but the first patent may be even old enogh to have ceased already. Would have to take another look at that because it many years that I had a look at that. The TI chip mentioned by 81bas is a fine example for a modern integrated carrier-based amp.
The same questions as Jan-Peter asked came up in my mind as well.
Charles
Old 25th February 2010, 06:38 AM   #26
deleted double posting - maybe a mod can remove the remainder as well !
Last edited by phase_accurate; 25th February 2010 at 06:41 AM. Reason: double posting
Old 25th February 2010, 06:45 AM   #27
Banned
Phase_Acurate:
if I have to be realistic, this is competitive even if cost 500 .
a pair of these in a case (wood and aluminum) 1U or 2U, finally the audiophile is happy without spending 6000
Old 25th February 2010, 08:27 AM   #28
81bas is offline 81bas  Germany
I like to see the optocouplers in this amp instead of some usual low/hi side integrated mosfet driver. No lockup problems, less requirements to the dv/dt characteristic, etc.
Old 25th February 2010, 08:53 AM   #29
Banned
for this performances ... were necessary 100ns, from modulator (outstage) to mosft gate,with custom dt.
somehow this has been achieved.
Old 28th April 2010, 05:52 PM   #30
savu is offline savu  Ireland
savu's Avatar
Send a message via MSN to savu
hello one question:
what does "rips uses 3 high speed mosfet to rotate pulses in trafo" ?
regards
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Class D kits for bass guitar amp??Hide this!Advertise here!
High gain guitar preamp kits! Hybrid_Child Instruments and Amps 1 15th July 2009 05:18 PM
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
Cheap guitar amp kits? leadbelly Instruments and Amps 7 25th July 2008 04:03 PM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
tube/valve bass amp kits achtung jackass Instruments and Amps 0 3rd October 2005 08:50 PM
