Instruments and Amps Everything that makes music, Especially including instrument amps.
Ross pc-4110 amp circuit or help
Old 6th October 2009, 02:39 PM   #1
VICK is offline VICK  South Africa
Default Ross pc-4110 amp circuit or help
How zit all ! Please help. Got this system in and people (bush technicians) already had a go at it.Want to try and repair , but not sure if the right transistors is in and if wired correctly. The output transistor is not solder on
the pcb. Instead it is wired. So now I dont know if it has the right parts in it and if it is wired correctly. Any one have advise or know where I can get the circuit.Will post pics if someone is willing to check it out.
Vick
Old 7th October 2009, 12:40 AM   #2
gain wire is offline gain wire  Canada
gain wire's Avatar
Hi Vick, yeah go ahead with the pictures, I'll give it a try. I love to debug!
The output transistor is wired? That is strange... Unless it's a TO-3 case mounted on a socket that had solder terminals.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
Old 7th October 2009, 03:51 PM   #3
gain-wire Thanks for reply will put up the pics A.S.A.P
Old 10th October 2009, 05:37 AM   #4
Enzo is offline Enzo  United States
if pc4110 is the board number, what is the make and model of the unit it is in?
Old 11th October 2009, 09:00 AM   #5
Here is the Picture's
Old 11th October 2009, 09:07 AM   #6
Here is another one.
Old 11th October 2009, 09:13 AM   #7
The last one.Thanks for the interest so far gain-wire and Enzo. The model number is the same as pcb. The output is Tip 35 c x 4. The drivers is Tip 31 c x4.
Vick
Old 12th October 2009, 05:04 AM   #8
APparently Musicparts.com will sell a copy for $20.
MAybe them:
Ross Systems
4710 Mercantile Drive
Fort Worth, TX 76137-3605
Old 12th October 2009, 08:50 AM   #9
Thanks Enzo for the reply.I know about Musicparts.com and found it
when I was searching for the schematic.Unfortunately it wont be worth to buy.
I will take time and figure it out or better yet just replace the amp.
Vick
Old 12th October 2009, 10:13 AM   #10
Nigel Goodwin is offline Nigel Goodwin  England
That's really an absolutely horribly constructed amplifier - however, it should be pretty simple to draw out the circuit of the power amplifier, which will make it pretty easy to repair.
Nigel Goodwin
Ross pc-4110 amp circuit or helpHide this!Advertise here!
Help with a DD circuit analog_sa Analogue Source 3 25th October 2011 06:43 PM
FS: 15" woofer from Ross B1550 bass amp Jimmy154 Swap Meet 1 26th March 2007 05:38 AM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Anyone know the JOB circuit? Ap Solid State 0 28th June 2002 01:43 AM
Copyright ©1999-2017 diyAudio
