Instruments and Amps Everything that makes music, Especially including instrument amps.
DIY Design and Build Overvoltage Input Amplifier Protection. HElp!!!
Old 14th September 2009, 12:24 AM   #1
thomgun_lc is offline thomgun_lc  Indonesia
Default DIY Design and Build Overvoltage Input Amplifier Protection. HElp!!!
I think to build some circuit to protect my input bass amplifier from overvoltage. Usually if we use onboard preamp/ overdrive effect, the output voltage from our bass/guitar output can damaged our amp. Eventhough there are an input protection circuit inside our amplifier, but i think, it is better to build a simple external device, which can protect from Loud "POP" sound and overvoltage, and we can change range of this protector circuit, so this devices not cut the sound without our permission/setup.
Does anyone have an idea???
Absolutely, we need to build the pure one, so this devices not change amplifier's sound charater.
I think it is better to sacrifice this devices if overvoltage occured than your MARSHAL JCM, SWR, FENDER, VOX and your another favorites amp.
Old 1st October 2009, 02:49 AM   #2
gain wire is offline gain wire  Canada
gain wire's Avatar
Hi there. It sounds highly unlikely that a signal from a Guitar or Bass can overload any preamp, designed to amplify bass or guitar signals. Unless you mean the noise caused by hitting the jack tip on the ground plate or something like that. Or maybe there's alot of static in your environement...
In any case, you want to have a simpel circuit? How's this:
two 3volt zener diodes, back to back (in parallel, anode to cathode, cathode to anode) one junction going to ground the other junction going to your signal. This will effectively clip any voltage over 3 volts. Or any other voltage you choose. It should not affect the sound quality. You will not find a more efficient, simpler circuit. I found this in Forrest Mims' simple transistor circuit book. Actually the same circuit is used to prevent damage to many preamplifiers and other sensistive input circuitry.
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig
DIY Design and Build Overvoltage Input Amplifier Protection. HElp!!!Hide this!Advertise here!
Overvoltage protection with filter Igla Chip Amps 4 27th February 2009 12:11 AM
Overcurrent, overheat and overvoltage protection for TL494 Janez Power Supplies 17 21st December 2007 02:36 PM
Which amplifier design should I build? SimontY Solid State 47 8th June 2007 03:28 PM
Input Protection Devil_H@ck Chip Amps 5 21st January 2007 04:49 PM
Protection of Mosfet Amps from input Overdrive... Workhorse Solid State 21 22nd June 2005 03:57 PM
Copyright ©1999-2017 diyAudio
