Instruments and Amps Everything that makes music, Especially including instrument amps.
ESP Guitar Preamp Output Swing
Old 29th August 2009, 12:52 PM   #11
mjf is offline mjf  Austria
[QUOTE=shaan;1909286]The page says that for the diodes the power amplifier must have a sensitivity of 750mV for full power. I plan to run it with my 20Watt SE Class-A amp which has a sensitivity of 1.5V for full power.
Is there any way to increase the preamp's output voltage swing while keeping the soft clipping behavior intact?
hello.
you can add another two diodes to the existing ones , so you will have three diodes in series on each half side...........
if the output is too low again go up to four diodes per side.
greetings..........
Old 18th September 2009, 10:55 AM   #12
shaan is offline shaan  India
shaan's Avatar
All done... after placing a gain-of-2 buffer yesterday I ran it and it's fine. The soft clipping is quite cool! Sounds almost like the "FL Slayer"'s default power chords or Inferno of the Sytrus synth of FL Studio.
Great preamp! 9/10
V4 GB! | V4H GB!! | PSU GB!!!
ESP Guitar Preamp Output SwingHide this!Advertise here!
Tested output swing on small chips johnr66 Chip Amps 0 16th March 2009 12:31 AM
Voltage swing on a guitar pick-up? Richard Ellis Instruments and Amps 3 12th February 2008 05:13 PM
Increase the output swing of LM3875,possible??? Leolabs Chip Amps 8 20th August 2007 02:50 AM
Need to get the highest voltage swing, which output topology? EWorkshop1708 Solid State 7 2nd March 2005 06:56 AM
guitar preamp offroadbum Instruments and Amps 0 14th February 2004 11:39 AM
