Instruments and Amps Everything that makes music, Especially including instrument amps.
Mesa Boogie bass amp quiet
Old 30th June 2009, 01:35 PM   #1
mekaiver is offline mekaiver  Aland Islands
Default Mesa Boogie bass amp quiet
Hello!
Im not a native english speaker so please try not to laugh OR laugh as much as u like but try to answer my question as well.
So, the problem is with a MB bass amp m-pulse 360. It was on a 4Ohm load cabinet and it wasnt cranked up when it just got like quieter. Not dead silence, but half as loud as it was before. I dont have a schematic, so its a bit harder to find the fault but im 90% sure that the end on mosfets is ok. Tried to change the tubes in preamp but nothing. The tubes are 2 ecc83. The strange thing is that
the voltage in kinda wierd on the valves.
According to this image http://en.wikipedia.org/wiki/File:EIA-9A.png
the volts are on the first tube starting from one 305, 0 , 0, 9, 0, 250, 0, 1 ,4
and the other ones are 350, 210, 210,4, 0, 211 ,0, 1, 4
Seems like the second tube grid and cathode are getting too much volts or am i wrong? Where to look, what and how to mesure?
Im not home with tubes but if someone shows me the way, maybe im able to find the faulty component and change it.
Old 30th June 2009, 01:52 PM   #2
azazello is offline azazello  Bulgaria
azazello's Avatar
It seems that in 2-nd tube-1-st triode, cathode resistor burned /cathode is open/. Check resistor. Check and anode resistor.
And than check cathode cap....Maybe it burned.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 30th June 2009, 06:23 PM   #3
Resistor is fine on cathode. And the only cap there is from cathode is going to the mosfets input. Out of ideas.
Old 6th July 2009, 03:51 PM   #4
No one knows heh?
Old 6th July 2009, 04:42 PM   #5
ChrisA is offline ChrisA  United States
Default Re: Mesa Boogie bass amp quiet
So the gain drops a lot but the voltages all still look reasonable?
I think a cap might be "open". Could be a cathode bypass cap. These are typically parallel with a resister. Its a likely to fail part too, electrolytic cap. If you remove one of those the DC voltages don't change but the gain on the stage is reduced. If a coupling cap opens you'd have no sound at all.
You are going to have to get a schematic, put a signal on the input and trace the signal level through the amp.
With the given information we are guessing. But my bet is on a cathode bypass cap.
Old 6th July 2009, 10:20 PM   #6
Thanks!
Will check the cap.
I know its a guessing, its a guessing to me too, cos i cannnot find the schematic either.
But thanks anyway.
Old 6th July 2009, 10:20 PM   #7
http://criz666.planet.ee/mesaboogie/ Some pictures may be helpful.:P
Old 7th July 2009, 06:16 AM   #8
Enzo is offline Enzo  United States
Are BOTH heaters glowing in that 12Ax7 with the 300,0,0 voltages?
Old 7th July 2009, 07:35 AM   #9
Seems so yes, as much as it is visable from the top.
Old 7th July 2009, 02:34 PM   #10
Gabdx1 is offline Gabdx1  Canada
Try another pre-amp / power amp, try isolate which component has weak gain. Because now it can be anything.
Mesa Boogie bass amp quietHide this!Advertise here!
Mesa boogie odem81 Instruments and Amps 15 18th April 2010 12:00 AM
Mesa Boogie DIY! Gabster Instruments and Amps 21 17th April 2010 08:18 PM
Mesa/Boogie Bass 400 psu Greg3333 Instruments and Amps 10 21st February 2010 08:08 PM
Mesa/Boogie Bass 400 clone PSU specs Greg3333 Power Supplies 1 26th October 2006 02:13 PM
Mesa Boogie Mark IV azira Instruments and Amps 7 13th December 2003 01:53 AM
Copyright ©1999-2017 diyAudio
