Instruments and Amps Everything that makes music, Especially including instrument amps.
bass speaker help
bass speaker help
Old 31st October 2012, 10:26 AM   #501
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
bass speaker help
new idea for a bass horn
could be the next project
based on my experiment here, I have concluded a big midbass horn is tricky
but also that it reproduce with a special big tuneful sound, and almost addictive
Old 31st October 2012, 02:45 PM   #502
Is this a W horn with a mid/treble pasted onto the front panel?
regards Andrew T.
Old 31st October 2012, 04:17 PM   #503
bass speaker help
my understanding of a w-horn is that its a bass horn
I guess you could call it a w-horn, since it looks like one
apart from its calculated to only 120hz(+/-)
and yes, the small widerange drivers on the front is an ispiration from Ingvar's Hilden horn project
Old 31st October 2012, 06:50 PM   #504
chris661 is offline chris661  United Kingdom
chris661's Avatar
I suppose you could add ports to the rear chamber to improve LF response a little.
Hornresp has this option.
Old 31st October 2012, 06:56 PM   #505
bass speaker help
would need much bigger back chamber ?
but I dont know
its not a real tough woofer
rather cheap 12" (Sovereign 12-300)
but ok quality with nice midrange
Old 9th November 2012, 07:08 AM   #506
bass speaker help
latest crossover revision, and now patent pending
its still surpricing how much even small crossover changes affects string tuning and pitch
Old 14th November 2012, 09:02 AM   #507
bass speaker help
just realised why not to use ordinary medium Qts drivers for front horns
and pretty obvious, peaked low rolloff in a small back chamber
apart from that, a 150hz horn looks easy
use all the available space for a backchamber it might still be possible
btw, I tried a small Onken slot port calculation with the 12" Sovereigh, and looks like it would work nicely
Old 20th November 2012, 09:16 AM   #508
bass speaker help
latest crossover revision......
another update on my weird xo
I can now fully understand why some people wisely avoid multiways for bass guitar
several times I have experienced tuning and pitch to go complete wack(off)
its certainly not simple at all
next crazy project, big weirdo 18" 'fullrange'
Old 20th November 2012, 07:27 PM   #509
Passinwind is offline Passinwind  United States
Passinwind's Avatar
Which modeling program are you using?
It's certainly not been easy, but in my case I have been really happy with the results once I threw enough time (and money!) at it.
Old 20th November 2012, 07:50 PM   #510
bass speaker help
ears and my guitar
actually, my ears just went complete wack
one ear closed, and it hurt a bit
changed a few resistors(again)
ears improved immediately
as did my playing
sound as such doesnt change much really
its all mainly phase issues
sure, crossover is not too good, its crap
just fooling around, needing components
in the meantime, I put my ears at risk
and its not a joke
bass speaker helpHide this!Advertise here!
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 04:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 09:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 05:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Copyright ©1999-2017 diyAudio
