Instruments and Amps Everything that makes music, Especially including instrument amps.
bass speaker help
bass speaker help
Old 5th June 2012, 08:41 PM   #471
lduarte1973 is offline lduarte1973  Portugal
Banned
you can choose see switch in picture
Old 5th June 2012, 09:18 PM   #472
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
bass speaker help
you mean the 'high/low' gain switch
its probably so that the fet input is on all the time, as a buffer, with the tube bypassed
switching to high gain, and the tube pre is on
but thats 'just' the preamp section, and got nothing to do with the output stage
my guess is that the mosfet power amp is also driven by solid state devices
in that sense the power amp is a pure solid state design
ups, I see now there is both a high/low input option and a switch to select either tube or fet input
but its still the same thing
its a preamp section, and seperated from poweramp
power amp seen seperately is most likely a pure solid state design
Old 5th June 2012, 09:53 PM   #473
Banned
yes , power amp solid state , preamp ss or tube by switch , itīs a hybrid like i said before
Old 15th August 2012, 09:12 PM   #474
bass speaker help
thinking about taking up my previously failed mid-bass-horn
Old 15th August 2012, 09:58 PM   #475
bass speaker help
pictures of horn mouth, and woofer mounting hole
btw, there are two horn mouths, one on each side
with wall and floor support it might do 100hz
Old 15th August 2012, 11:21 PM   #476
bass speaker help
to those who wonder what this is all about
its calculated like a frontloaded horn
but built like a backloaded
and I was using a semi pro 15" with too high Qts
or at least I think its a major part of the problem
so, the project is to mount the woofer 'inside', giving it a small back chamber, as it should be have been from the start
Old 16th August 2012, 07:26 AM   #477
bass speaker help
possibly this 15" woofer http://www.precision-devices.com/asp...s/super/48.pdf
Old 16th August 2012, 01:17 PM   #478
bass speaker help
bigger hole, chop chop, bracings split to pieces
Old 22nd August 2012, 09:09 AM   #479
bass speaker help
found a maybe more appropriate 12" with nice specs
appears to be good quality, and still affordable
Old 22nd August 2012, 05:40 PM   #480
Keriwena is offline Keriwena  United States
Fanes have a good reputation. Not that common in this country, but the players that use them, love them.
bass speaker helpHide this!Advertise here!
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 05:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 10:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 06:06 PM
15" speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 03:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 01:17 PM
Copyright ©1999-2017 diyAudio
