Instruments and Amps Everything that makes music, Especially including instrument amps.
bass speaker help
bass speaker help
Old 22nd May 2012, 04:52 PM   #441
lduarte1973 is offline lduarte1973  Portugal
Banned
would be good to have bass/mid/treble control
Old 22nd May 2012, 05:00 PM   #442
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
bass speaker help
no, only 2 will work, if you want a smooth control
should be able to do something like this
Old 22nd May 2012, 05:13 PM   #443
bass speaker help
ups, you are right
I forgot the bass EQ
not sure what will be optimal bass control
Old 22nd May 2012, 06:44 PM   #444
bass speaker help
ehh, probably the same again, it would optimally consist of 2 controls, with a mutual centre frequency
Old 22nd May 2012, 06:54 PM   #445
bass speaker help
ahh, that would be a James Baxandall curcuit, right ?
Old 22nd May 2012, 07:20 PM   #446
Banned
yes , some ibanez basses have 3 freq eq
Old 22nd May 2012, 07:26 PM   #447
bass speaker help
and a search on John Bingham tone control gave this result
http://www.diyaudio.com/forums/solid...need-help.html
Old 22nd May 2012, 07:50 PM   #448
chris661 is offline chris661  United Kingdom
chris661's Avatar
Get one of these.
Despite being made before I was born, there's still plenty of life in there.
Stereo 150w/ch @4ohm (has the voltage swing to do much more - I measured 100V one-way, bridged into 8ohm).
Also has the facility to run with its own active crossover: there's a dial on the back going from 120Hz to 2kHz, and a balance control for between the two. Each channel also has its own FX loop and line out.
I'm running it stereo into my 4x10" cab wired for 2x4ohm.
Effing loud when needed.
Mine cost me 150. There are other models with other features - I've seen basic 100-150w ones go for <100 on eBay.
But yeah, tonnes of headroom, lots of facility for shaping your sound, and very cheap for what they are.
Chris
Old 22nd May 2012, 08:33 PM   #449
bass speaker help
hey, Chis, that one looks great
well, Im heading towards a single band parametric with a Bingham tilt control
but how to is the bigger problem
Old 23rd May 2012, 12:01 PM   #450
bass speaker help
hey, you may be right about it
looking at stereo unit, and hope to change to using 6 mono controls instead
might be nice being able to switch fast between 2 different settings
and even further, the two 'channels' could also be configured slightly different
that would be for the mid only
woofer might have a simple 2hannel parametric
bass speaker helpHide this!Advertise here!
Which pa speaker is the best for deep bass Bull PA Systems 8 11th December 2010 04:35 AM
AQA*Bass Box + SUB speaker ? Krokotam_ Subwoofers 0 27th October 2008 09:20 AM
Enclosure for a mid-bass speaker? neur0tic Multi-Way 3 2nd September 2007 05:06 PM
15&quot; speaker for a bass cabinet Zaireeka Instruments and Amps 0 29th August 2004 02:11 PM
bass speaker design help dbaudio Multi-Way 0 12th September 2003 12:17 PM
Copyright ©1999-2017 diyAudio
