Instruments and Amps Everything that makes music, Especially including instrument amps.
Ampeg SVT cloners, chime in!
Old 14th May 2009, 10:46 AM   #1
showdown is offline showdown  Norway
Default Ampeg SVT cloners, chime in!
I'm planning an SVT-alike using the power section of a Simms-Watts PA200 (4xKT88 UL) and would like any kinds of tips and tricks regarding cloning the SVT preamp on turret/tag boards. Opinions re: the various versions of the preamp are also welcome.
The PA amp is in pretty good condition inside, but the pots are wrecked and it needs tubes and a recap. I'm going to start with testing the transformers (huge things, I've read that they used Partridge iron in these) and if they check out OK I'll start with the project.
I know someone will be freaked out by me "destroying" an old piece of tube gear, but as I see it, it's completely useless to me as a PA amp... besides, I've always wanted a big tube bass amp
Old 14th May 2009, 04:27 PM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I wish you a good luck and suggest to develop own layout since original Ampeg SVT has errors that cause hum and HF oscillations. Pay attention on ground connections.
However, the problem will be to obtain an inductor, but you may use several inductors instead of one with taps.
The Devil is not so terrible as his math model is!
Ampeg SVT cloners, chime in!Hide this!Advertise here!
atention to kharmas cloners elviukai Multi-Way 0 26th June 2006 07:37 AM
Ampeg Amp Value audiopro Instruments and Amps 0 2nd August 2004 04:09 PM
Any Virgo cloners out there? Nordmann Multi-Way 0 1st October 2001 12:35 AM
Copyright ©1999-2017 diyAudio
