Instruments and Amps Everything that makes music, Especially including instrument amps.
The secrets of guitar amplifiers
Old 23rd April 2009, 08:40 PM   #41
bear is offline bear
expert in tautology
bear's Avatar
Actually absolute phase might come into play depending almost entirely upon how you play, what your tone settings are and most importantly IF your sound includes a lot of real low end or "chunk" - the way the cone moves when you hit the strings is either going to be in or out.
Playing solo, or without anything other than bass &/or drums, this can be part of one's sound. It is for me. So I do try to set it up so that when I whapp" the strings it gives a pulse out to the audience... of course with other guitar and other instruments, the low stuff just muddies up the sound and gets in the way usually, so then it really makes little difference.
It might matter a bit if you are doing some "critical" recording - and you might notice a bit of diff in the total tonality of a given track depending on the absolute phase of the track, AND the absolute phase of the output of the rig (assuming you've been mic'd).
But otherwise, rather irrelevant, imho.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 23rd April 2009, 10:54 PM   #42
ian_carney is offline ian_carney
Default good source of curcuit diagrams
is www.schematicheaven.com
it does just what it says on the tin
Old 23rd April 2009, 11:15 PM   #43
b_force is offline b_force
I know the website
Here some more(with a lot of schematics!)
http://www.bnv-gz.de/~ooehmann/
http://tremolo.elektroda.net/tematyk...&adres=Firmowe
http://www.drtube.com/index.htm
Old 23rd April 2009, 11:23 PM   #44
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally posted by b_force
But if you at another tube, the signal will be Pi rad or 180 degrees out of phase.
It's normal, if you don't use 2 amps in parallel feeding them from the same source. Absolute phase between line out and microphone matters when miking; in case of an opposite polarity lows will be thinner.
The Devil is not so terrible as his math model is!
The secrets of guitar amplifiersHide this!Advertise here!
Info on guitar amplifiers krataratata Instruments and Amps 2 11th March 2009 02:56 AM
Bias secrets for a HH Scott 233?!? adamamp Tubes / Valves 2 15th February 2005 03:30 AM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 09:24 PM
Paradigm amplifiers? Anthem amplifiers? Corn-Picker Solid State 2 24th January 2004 04:10 AM
Many smaller amplifiers vs. bigger amplifiers. djdan Solid State 9 17th September 2002 05:40 PM
Copyright ©1999-2017 diyAudio
