Instruments and Amps Everything that makes music, Especially including instrument amps.
Paia stack in a box
Paia stack in a box
Old 21st March 2009, 03:39 PM   #1
Dusk is offline Dusk  United States
Dusk's Avatar
Smile Paia stack in a box
Hi
Awhile back there was a thread about Paias tube stack in a box tube pre-amp,here is my take on that: Hafler P-500 power amplifier,DoD eq and and a ETA Power Conditioned than it goes into a 200watt homemade speaker cab. the EQ is a DoD 430.
Old 21st March 2009, 04:35 PM   #2
Minion is offline Minion  Canada
I recently built an amp useing the Stack in a Box as a Preamp and it sounds freaking awesome....
Mine is a Modded Stack in a Box ( modded for 1000x Gain and useing fet opamps at the input) Mine also has a 15 bands EQ with is consumer gear I intedgrated into the amp and for the power amp I used a TDA7293 100w Mosfet power amp IC with 40,000uF Capacitance in the PSU and a 200vA 2x28v AC Power transformer...
It"s not pretty but sounds great...
Cheers
Thinking about adding a simple compressor to it also...
Old 24th May 2015, 10:27 AM   #3
Dusk's Avatar
Smile Paia tube preamp
Hi i know this is old,but here is my rig
Dusk
Old 24th May 2015, 10:38 AM   #4
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Old warhorses resist to die
Sound must be killer, and definitely versatile.
Old 24th May 2015, 10:45 AM   #5
Dusk's Avatar
Thank you,and yes it is very versatile
Thank again JMFahey ;-)
Old 24th May 2015, 01:49 PM   #6
Dusk's Avatar
Smile 12ax7 preamp
Here is a 12ax7 diy preamp on the very top(in picture)
Dusk
Paia stack in a boxHide this!Advertise here!
Paia tubehead mod's? Optical Tubes / Valves 2 6th April 2013 01:55 PM
Paia Fatman Pot replacements arjun Instruments and Amps 4 20th March 2005 10:23 PM
Paia Tubehead questions tiroth Tubes / Valves 3 4th April 2002 11:20 PM
Copyright ©1999-2017 diyAudio
