Instruments and Amps Everything that makes music, Especially including instrument amps.
Piezo switch to trigger drum lights
Old 5th March 2009, 03:45 PM   #1
jman 31 is offline jman 31  United States
jman 31's Avatar
Default Piezo switch to trigger drum lights
I am trying to design a simple circuit that would work with the piezo transducers on a set of electronic drums to trigger an LED when the drum head is struck. I am using a simple MOSFET switching transistor, with a 9v battery and an LED. The led has a built in resistor to handle the voltage although that is not shown on the schematic.
Can someone take a look at this and see if I have it set up properly, and if there is anything that would work better?
Jeremy
Old 5th March 2009, 08:29 PM   #2
jman 31's Avatar
I went ahead an built this circuit to test it, but now I've hit a slight snag. I will have to rely on some of you electronics experts on this one. When I use a piezo in the shell to trigger the light, it generates about 1 volt before the light will trigger. When i use a drum trigger, even when I hit it fairly hard, I am only generating about .3v.
I need the transistor to switch at around .25v.. I couldn't find the one that was specified (ZVN2106) on the schematic, so I used this one. This has a much higher voltage threshold and I was wondering if the one that is specked out will switch at a lower voltage from the piezo?
Any help would be greatly appreciated!
Jman
Old 5th March 2009, 11:39 PM   #3
jman 31's Avatar
It occurred to me also that the diode is interfering with my voltage. Is there another way to protect this circuit and not lose the precious voltage? And is my reasoning sound on this? I can't have the voltage from the battery getting back to the piezo. Also can the current even go that way through the transistor? Oh my head is starting to ache!
Old 16th February 2010, 11:27 AM   #4
BenLucid is offline BenLucid
So did your LED trigger work?
Old 2nd March 2010, 01:44 PM   #5
jman 31's Avatar
Not as shown above. Have a look here to see the progress.
I am now in the process of building a midi trigger for drum lights. You can read about it HERE and HERE.
You may have to register to see the pictures. Sorry to send you to another site, but I can't begin to reproduce all of the info here.
Piezo switch to trigger drum lightsHide this!Advertise here!
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 02:54 PM
Piezo Transducer Trigger 4A Analog Simmons Drum Module modorange Instruments and Amps 8 21st December 2007 05:23 AM
Main on/off switch for amp using a piezo switch using_e Solid State 13 20th June 2006 06:55 PM
piezo switch? garbage Parts 5 31st July 2005 07:06 PM
