Instruments and Amps Everything that makes music, Especially including instrument amps.
Spring Reverb Units
Spring Reverb Units
Old 3rd March 2009, 12:35 AM   #1
TGRANT is offline TGRANT  United States
Default Spring Reverb Units
Two general and basic questions about spring reverb units.
I am building a solid state guitar amp, and I bought a new Acutronics spring reverb unit.
First question. When I build the amp, where and how does one hook the reverb unit into the circuit? I assume somewhere in the preamp stage, but where exactly is the best place to put it? Iíve seen tube amp schematics that show various configurations, but I havenít been able to put my hands on a solid state preamp that shows how to incorporate a reverb unit.
Second, when scope testing the unit hooked into a driver and recovery circuit, what kind of wave form should I see so I know that the reverb circuit it is doing what it is supposed to do? I breadboarded the driver and recovery circuits exactly as the Acutronics web site described, and hooked in the unit. I ran a sine wave through the circuit. The input and output wave forms looked exactly the same. Does that mean itís not working? What does a Ďreverbedí sine wave look like? I expected to see at least some disturbance of the wave, but it was reproduced almost exactly.
Old 3rd March 2009, 12:52 AM   #2
ceharden is offline ceharden  United Kingdom
Try testing it with something other than a sine wave. The reverb tank can only delay the signal. If you take a single frequency sine wave, delay it, then add it back to the original, the output is just the same wave with the amplitude and phase changed.
A pulse signal should show the effect of the spring reverb.
Old 3rd March 2009, 01:21 AM   #3
llwhtt is offline llwhtt  United States
With your test rig up and running monitor the output with the scope and then vary the test frequency. The output should go all "goofy" if it's working correctly. Varying the amplitude will get some "goofiness" but not nearly as much as the frequency.
Craig
Old 3rd March 2009, 01:31 AM   #4
Default Reverb
Many thanks, that worked. I tested it with a square wave and as I increased the reverb level, the square wave sloped down. Actually, the rise level increased, rang a bit, then sloped down. Interesting. I guess I forgot what I knew about sine waves - add two sine waves and you get a sine wave. I could attach a phot of the scope if anyone is interested.
As you would expect, the shape of the wave changed as the frequency varied. Hope this info helps someone else.
By the way, I have the reverb located between two op amps in a two-stage tone control for this particuylar test.
Old 3rd March 2009, 04:17 AM   #5
audiohead is offline audiohead  United States
Craig:
Thanks 4 your scientific response.
Art
Old 3rd March 2009, 04:56 AM   #6
Art,
You're welcome.
Craig
Old 3rd March 2009, 06:23 AM   #7
east electronics is offline east electronics  Greece
east electronics's Avatar
Default i would be very interested
i am mostly wondering what causes what you described as ringing ..... i ve seen it while repairing some transistor amps and i wasnt able to detect what causes that in some cases
thanks
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 4th March 2009, 01:50 AM   #8
Default ringing
Iím not an expert, but some ringing is caused by resonance that is then dampened, for example the damped oscillation of an output transistor into a reactive load. Iím thinking thatís to some extent what a reverb circuit is. The springs are certainly reactive, but of course the load shouldnít be (the load in my test circuit was a simple non-inverting op amp). Iíd be curious if any of the more knowledgeable people have any comments on this one.
Old 4th March 2009, 02:22 AM   #9
There are two transformers also, one at each end of the spring.
Craig
Old 4th March 2009, 02:30 AM   #10
Default spring reverb
What determines the load impedence of the reverb circuit - the transformers, or the input impedence of the recovery circuit? The recovery circuit on the Acutronics web site appears to be a straight forward non-inverting op amp that should have a very high input impedence and should not be reactive. Is that correct reasoning?
Spring Reverb UnitsHide this!Advertise here!
SR-101 Pioneer Spring Reverb StrangeDesign Tubes / Valves 13 27th June 2010 03:57 PM
building spring reverb Redfoxfur Instruments and Amps 26 24th June 2009 05:07 AM
Spring Reverb transformer ThSpeakerDude88 Instruments and Amps 6 18th April 2007 04:17 AM
Transducers for a spring reverb seilee Instruments and Amps 3 5th December 2006 03:56 PM
Help - tube driver for spring reverb... memphissound Instruments and Amps 8 16th September 2005 06:51 AM
Copyright ©1999-2017 diyAudio
