Instruments and Amps Everything that makes music, Especially including instrument amps.
whu 6800ohms for mic phantom pwr?
Old 18th February 2009, 09:16 AM   #1
SemperFi is offline SemperFi  Wake Island
Default whu 6800ohms for mic phantom pwr?
I'm just wondering why all phantom powers for mics have 6800ohm resistors in series? Was it b/c that happens to be about 10x the old standard 600ohms?
Old 18th February 2009, 10:32 PM   #2
Minion is offline Minion  Canada
P 48v standard has allways had 6.81k resisitors comeing off of the phantom supply , never heard of 600 ohm resistors on a phantom supply , are you sure you aren"t thinking abount the old 600 ohm input/input impedance standard???
anyways those resistors are there for current limiting , so if there is a short on the mic or the phantom supply you have less chance to frying your mic or your preamp, and less chance of frying yourself....
Old 19th February 2009, 06:30 AM   #3
Thanks. With the 600ohms I meant source (microphone) or line impedance, which was universially set to 600ohms in the old days, and the 6800 becomes the textbook 10x load.
My understanding is that the phantom power is use to bias the mic condenser capsule, and not power an actual mic preamp. Am I right about that? ...Just as I write this I realize a condenser capsule has extremely high impedance and this cannot be...it must have a preamp right next to it, at least a simple High-Z buffer.???
I guess I need to read more about mic interfaces.
Old 19th February 2009, 04:20 PM   #4
Nigel Goodwin is offline Nigel Goodwin  England
As you say, mikes are usually nominally 600 ohm, the phantom power resistors are part of the load resistance on the mike, so picking a value ten times higher means it doesn't load the mike.
Nigel Goodwin
whu 6800ohms for mic phantom pwr?Hide this!Advertise here!
Phantom Power might be Bad? mistermisfit Solid State 12 10th February 2010 08:22 PM
+/-15V from +48V Phantom Pilbromatic Parts 4 9th August 2009 05:46 AM
phantom pcm 1732 dillo Digital Source 14 15th December 2005 05:37 PM
Using the phantom power Gabevee Instruments and Amps 2 29th July 2005 05:32 AM
phantom powering non-phantom mics karambos Instruments and Amps 8 3rd January 2004 09:21 AM
