Ferrit beads on the power supply regulator legs always seems to help the automotive stuff I build. You would not belive how electrical noisy engines are.
winner said:i made a guitar preamp using op amp tl074 with 1 mega ohm
impedance and voltage gain of 100 . but its too noisy and
also lot of hum? will using a voltage reg like 7812 help or
is it .coz of the opamp quality?
Guitar pickup pre-amps are tricky because they are so high impedance. I would have thought you'd have to go to a discrete JFET input to keep the noise down.
The 20KHz bandwidth thermal noise in a 100Kohm resistance is 5.8uV or 41nV/rt.Hz. The TL074 has a 1KHz noise figure of 18nV/rt.Hz which rises to more like 25nV/rt.Hz at 100Hz. Add a gain of 100 and the noise is getting pretty high.
The mains hum is due to leakage currents flowing in the high impedance input. A regulator won't help I'm afraid. Attention to grounding and use of shielded cable is the key.
Can you post the schematic? It's hard to guess exactly what the problem is.
