Instruments and Amps Everything that makes music, Especially including instrument amps.
Effects mixer for pedals etc? Help needed!
Old 17th December 2008, 03:21 PM   #1
Haans is offline Haans  Norway
Default Effects mixer for pedals etc? Help needed!
I've been looking for a specific piece of equipment, but I can't seem to find anything like it anywhere. What I need is a simple (?) mixer that lets an audio signal pass through a chain of effects and lets me adjust the amount for each effect using a potmeter.
Was that clear?
Maybe not. I'll try the more graphic approach:
Synth -> Effect Mixer -> Amp
. . . . . . 1 2 3 4 5 6 7 8 . . . .
Where 1-8 are inserts controlled by an "amount"-potmeter. Each insert will have a pedal/effect connected, for example different fuzzes, reverb, echo, tremolo, all preset to whichever sound I want from them. That way I will be able to control just the amount of each effect added to the signal, or remove an effect entirely from the mix without having to stomp the pedal (which can cause annoying volume-drops, dropouts or clicks/pops).
Is this even possible?
Old 17th December 2008, 03:37 PM   #2
HK26147 is offline HK26147  United States
Check out audioXpress 1/07: "Low Level Analog Switching".
It details how to implement self latching relays to switch in and out effects without having the traditional daisy chaining.
This should eliminate the pop/click problem and cleanup the FX chain.
Syd
Old 17th December 2008, 05:25 PM   #3
Thanks for that, I will try to track it down. Still, one of the main reasons I want a mixer is that I want to be able to control the amount of each effect in a simple fashion, without having to dabble with all the controls on each pedal/effect unit.
Today I daisy chain all the effects and manipulate a sound source (bass, synth, guitar etc.) by turning effects on/off or adjust the properties of each effect. That's fine, but means a lot of fiddling with knobs at times when I just want to reduce the amount of an effect.
I basically just want 6-8 aux send/returns daisy chained, one pot to control each one.
Old 17th December 2008, 06:14 PM   #4
The switching arrangement I mentioned could provide a separate feed for every effect, so each FX line could be run into line in an 8 chl. mini-mixer, and the volume of each controlled by each channel slider.
I don't know about the particular options for your FX set: Some devices allow pedal control of volume or wet/dry mixing or automation via MIDI triggering.
Depending on your needs you may be able to get by with a simple splitter like
Alto Link - Eight Channel, Rack-Mounted Mixer / Splitter
8 out each line has a pot.
Old 18th December 2008, 07:21 PM   #5
Markus2006 is offline Markus2006  Poland
I think that such a mixer can be build using this schematic: http://seanm.ca/stomp/images/bblender.gif . Of course you may repeat as many stages as you need.
Mark
Old 18th December 2008, 08:55 PM   #6
Hm, that definitely looks like what I want. I'm unsure as to how it would behave if repeated 8 times, but I suppose small modifications would make that work just fine. I think I'll have to shoot off an e-mail to Sean.
Thanks for pointing me in the right direction!
Old 19th December 2008, 10:26 AM   #7
You may also take a look at: http://www.runoffgroove.com/splitter-blend.html (with some modifications).
Mark
Effects mixer for pedals etc? Help needed!Hide this!Advertise here!
What polarity is the plugpack on Boss pedals? Caleb Chia Instruments and Amps 13 15th October 2009 07:53 PM
Effect pedals vs amplifier EQ. moo Instruments and Amps 4 26th November 2007 04:01 AM
marshall efect pedals : Info pls pinky78 Instruments and Amps 0 12th July 2006 10:39 PM
Effects Pedals Petrix Instruments and Amps 9 13th November 2004 08:22 AM
WaH wAh PeDaLs! guitargully Instruments and Amps 9 2nd January 2004 06:44 PM
Copyright ©1999-2017 diyAudio
