Instruments and Amps Everything that makes music, Especially including instrument amps.
Hexaphonic guitar pickup experiment
Old 21st March 2009, 04:31 AM   #11
Sloan is offline Sloan  United States
Send a message via AIM to Sloan Send a message via Yahoo to Sloan
I read an interesting interview with Neil Young's guitar/amp tech where he mentioned doing something similar on Young's acoustic guitar. Some of the strings are panned left and some right, you can hear it on Rust Never Sleeps. Sounds great.
Old 22nd March 2009, 03:38 AM   #12
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
Ampeg made a guitar with split pickups (top 3 strings and bottom 3 strings) back in the 60's and ran the separate outputs through a phasing switch and separate tone controls. it had some very interesting sound combinations with that phase switch.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 8th December 2011, 02:18 PM   #13
GuyDenruyter is offline GuyDenruyter
Default Possible for kelstone? (9 strings)
Hi, do you think it would be possible to build such pickup for a kelstone (which has 9 strings)? And, would it be possible to include some DSP?
Old 9th December 2011, 06:51 AM   #14
phase_accurate is online now phase_accurate
Some thirty years ago ARP sold a quitar synthesiser that was fed via a hex pickup.
If you are using effects that generate a lot of hash (=IMD) when driven with mixed frequencies (like fuzz) or that won't work at all (like frequency dividers and doublers etc). It would be a clear advantage to chordal playing when you use such pickups and multiple parallel effect ways.
I own an ERB and sometimes I think it would be great to use pickups the are splitted and that feed two seperate EQ sections on a preamp. When the instrument spans such a large range it is quite possible that one string's bloom is the other one's boom and that's where such a system would help.
Charles
Old 24th February 2012, 05:55 PM   #15
pinkjimiphoton is offline pinkjimiphoton  United States
i bought one of those game controllers with the 6 string guitar on evilbay just to get the hex pup off it...gonna be fun to play with. have uses hex pickups with my midi'd guitars for years, they're very cool and useful...there's been a lot of commercial variants, even kramer marketed one back in the 80's...the thing is tho, that for most people, it's overkill..that's why they've never been more popular.
Old 24th February 2012, 06:40 PM   #16
cyclecamper is offline cyclecamper  United States
Phil Lesh (Grateful Dead) used quad bass pickups. Sometimes even completely seperate amplification and speakers for each string. His bass wasn't mic'd thru the main PA either, instead of going thru the main board it had its own volume footpedal under the mixing board table, and its own sound system.
The idea has a lot of merit for extremely clean sound IMHO. You can make a single-string pickup with quite a bit of output but not too much resistance or inductance (which cuts the treble) if you really try.
For 'active'...something like high-voltage phantom power for three 12AX7's right in the guitar could make me pretty happy.
Old 25th February 2012, 01:14 AM   #17
see if you can find an old line printer that used hammer solenoids (Printronix or older Genicom or Manesmann-Tally with the big "wobbler" cam). the hammer solenoids are about the right size for building pickups from. there were also some large (3"dia with a 3" long "nose") dot matrix printheads that had 24 solenoids arranged in a circle, and the solenoids were replaceable, and these are another source of coils the right size for a pickup. these printheads were used in NCR check processing machines for printing a bank's endorsement on the back of the check, but i'm sure they were used in large dot matrix printers of some kind elsewhere.
one thing, however, printer solenoids often need to be soaked in alcohol to get all of the ink residue out of them.
Hexaphonic guitar pickup experimentHide this!Advertise here!
Sustainer guitar pickup cartem Instruments and Amps 1 2nd July 2009 10:53 AM
Guitar pickup balanced preamp MisterStarshine Instruments and Amps 31 16th May 2009 08:48 PM
guitar pickup fading ThSpeakerDude88 Instruments and Amps 4 31st January 2006 06:15 PM
pickup buliding for toy guitar? voteforgoat Instruments and Amps 3 14th April 2005 08:26 AM
Copyright ©1999-2017 diyAudio
