simple guitar push pull amp simple guitar push pull amp - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 7th August 2008, 02:50 PM   #1
dan _s is offline dan _s  Israel
dan _s's Avatar
Default simple guitar push pull amp
Hello all
i have a small Peavy guitar amp+speaker cabinet. i'd like to build a tube amp to replace the transistorized unit in the cabinet. i have a push pull output transformer which i could use for that
what i'm looking for is the schematics for a guitar amplifier to which i can incorporate the speaker and transformer. it may use a pair of 6550 or EL34. preferably with an option for overdrive / distortion modulation
the the transformer has primary impedance 4500ohm, secondary 8ohm. the cabinet has one driver, resistance 3ohm.
i got a referal to this webpage http://www.drtube.com/guitamp.htm it contains hundreds of circuits but there's no way to browse this list by amp specs. i'd also like recommendations for proven designs
thanks
dan
Old 7th August 2008, 04:07 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
First of all, please identify the original thread when you cross post the same question to a different forum.
Also, I am not sure all of your requirements can be met. You have a 4.5K:8 OPT, a 3 ohm speaker, and want to use a pair of 6550's or EL34's.
If you use that transformer with a 3 ohm (let's call it 4 ohm nominal) driver, the primary impedance will be 2.25K. That's too low for 6550's or EL34's, especially if you expect to drive the output stage hard for a dirty sound.
So, what do you want to compromise? If you must use that transformer, you should either pick a different tube to use, or maybe use a quartet of lower power tubes (e.g. EL84's or 6V6's). Or do you insist on your tube choice and want to buy a different transformer?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 7th August 2008, 05:00 PM   #3
dan _s's Avatar
i didn't i would make a difference, my first post on this matter in this BB system was here
what i have in hand is the OP transformer (a pair in fact) and the driver in the cabinet. i don't care which tube to use as long as it's electrically suitable and easy to find and buy
i also bare in mind the possibility that the what i have may not fit together
Old 7th August 2008, 07:44 PM   #4
leadbelly's Avatar
Well, frankly, because there are so many choices out there, I'll have to move into subjective & personal opinions.
You want a proven design. To me that says clone a classic amp and stay away from the AX84 ilk (I know I may be spammed for this). For that OPT, you can build a Vox AC30 clone with a quad of EL84's or a Fender variation with a quad of 6V6's. If you are thinking practice amp those are too much power so use a quad of 6K6's.
Old 10th August 2008, 12:25 PM   #5
dan _s's Avatar
Thanks!
Old 10th August 2008, 12:44 PM   #6
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Leadbelllly's advice makes good sense.
Leadbelly": I know I may be spammed for this
I hate to disappoint: SPAM!
Old 11th August 2008, 07:03 PM   #7
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Why? Surely a guitar-amp dedicated website is exactly the place to hang around, if you're into that sort of thing...
Old 11th August 2008, 10:10 PM   #8
mashaffer is offline mashaffer  United States
I got a lot of very good help from the AX84 guys on my build. I ended up using their preamp schematics to develop mine. I used a 6V6 18Watt style output though.
Generic Signature
Old 12th August 2008, 01:02 AM   #9
leadbelly's Avatar
I guess the spamming is starting I was referring to designs of that ilk. He wanted a proven design so I told him to clone a classic amp rather than build a DIY design that few people have built.
simple guitar push pull ampHide this!Advertise here!
6v6 push pull guitar amp schematic sought guitar_joe Instruments and Amps 40 12th April 2013 06:26 AM
50c5 push-pull for guitar? freefallingegg Instruments and Amps 33 18th October 2010 09:27 PM
Guitar amp, push pull dan _s Instruments and Amps 4 8th August 2008 09:26 AM
simple 6v6 push-pull schematic ? vlljpior Tubes / Valves 6 30th November 2004 08:13 PM
A very simple push-pull project darkfenriz Solid State 5 6th September 2004 09:26 AM
Copyright ©1999-2017 diyAudio
