Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar Cab - Need help with Ohms
Old 5th August 2008, 03:42 PM   #1
anakinjay is offline anakinjay  United States
Default Guitar Cab - Need help with Ohms
Hey guys,
I'm building a 4x12 guitar cab... and I need help figuring out what ohms of speakers to buy.
I'd like to buy 4 of these:
(8ohms 100 watt)
http://www.musiciansfriend.com/produ...00w?sku=660186
but the power amp I want to use with them (only because I have it sitting around not doing anything) is this:
(2x1,200W @ 2 ohms; 2,400W @ 4 ohms bridged)
http://www.musiciansfriend.com/produ...Amp?sku=480697
And for the life of me, I can't figure out what would be the best speaker ohms / wiring setup.
Any help would be greatly appreciated... thanks!
Old 5th August 2008, 03:56 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Resistances in parallel divide, in series they add up. So, your 4 speakers of 8 ohms paralleled give 8/4 = 2 ohms.
If you put two in series, that's 16 ohms. Then, if you parallel two of those series sets of 16 ohms, the whole thing has again 8 ohms. That is probably the best solution. What's the amp's power in 8 ohms?
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 5th August 2008, 04:55 PM   #3
R.I.P.
You could go 4 x 4 ohm http://www.musiciansfriend.com/produ...00w?sku=660185
However see Section 3 of the amplifiers manual :
It states you should use 8 ohm speakers per channel for optimum
operation, which is very, very different to using 2 ohms per channel.
(In bridged mode this implies 16 ohms compared to 4 ohms).
In reality it needs to be able to drive 8 ohms bridged which implies
it also must be able to drive 4 ohms per channel when in stereo.
It also states they should be 8 ohm and > 450 watts per channel.
Which those drivers at 100W each they do not match up to.
You could wire up the 8 ohm drivers as 16 ohm per channel
(stereo cabinet) for the least chance of blowing them up.
You could get the 4 ohm version of the drivers, wired as 8 ohms per channel.
Or go for 200W drivers. 4 x 8 ohm. Either way of wiring them will
not matter. 2 x 4 ohm per channel (stereo parallel pairs) or
bridged into 8 ohms series / parallel wiring.
/sreten.
Old 5th August 2008, 08:30 PM   #4
"What's the amp's power in 8 ohms?"
I have no idea :P
The spec sheet only lists 2ohms or 4 ohms. Is there a way to find that out?
Also just to make sure I'm understanding correctly...
If I have 4 8ohm speakers.
I wire speaker 1's positive to the terminal positive... speaker 1's negative to speaker 2's positive, speaker 2's negative to the terminal negative...
Then..
I wire speaker 3's positive to the terminal positive... speaker 3's negative to speaker 4's positive, speaker 4's negative to the terminal negative...
right?
Old 5th August 2008, 08:30 PM   #5
after some quick googling, I believe at my amp is 2x500 watts @
8ohms
and the total wattage for the cab should be around 400. (with those speakers)
Old 6th August 2008, 01:42 PM   #6
R.I.P.
Yes that will give you a 8ohm 400W mono cabinet.
Which should be used with up to ~ 200W for reliability.
As it is mono you need to bridge the amplifier.
You can expect ~ 1.5kW in bridged mode 8 ohms.
That is ~ 3 times the per channel rating into 8 ohms.
You will blow up the speaker at some point.
Your safest bet is 2 x 16 ohm stereo unbridged.
(wire each side 2 drivers in series)
You will get ~ 250W a side.
If your rig is not stereo use parallel mode.
see here for stereo cabinet wiring
http://www.diyaudio.com/forums/showt...hreadid=103549
but you need to change it so its 16 ohms a side / 8 ohms mono.
/sreten.
Old 7th August 2008, 10:12 AM   #7
digitalstore is offline digitalstore  United Kingdom
/sreten.
hi anakinjay,
This is the perfect answer for you.
Guitar Cab - Need help with OhmsHide this!Advertise here!
4x12 Guitar cab using guitar and bass speakers help andrewskaterrr Instruments and Amps 15 23rd April 2009 11:43 PM
Ohms? ddoyle Multi-Way 6 3rd February 2009 03:38 AM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Speakers: 8 ohms vs. 16 ohms KT Multi-Way 2 14th April 2006 05:06 PM
ohms trip-wire Everything Else 9 25th December 2002 09:05 PM
