Instruments and Amps Everything that makes music, Especially including instrument amps.
Help finishing Albert Kreuzer's preamp!
Old 3rd January 2008, 11:32 AM   #1
Eugenio70 is offline Eugenio70  Mexico
Question Help finishing Albert Kreuzer's preamp!
Hi. I need help finishing an Albert Kreuzer's Bass preamp (http://www.albertkreuzer.com/preamp.htm).
I just need to add the two source resistors for the JFETs, and now I see I really don't understand the procedure to select them! I'm using 2N5457 JFETs, thats whats available here. I don't have access to an oscilloscope but I saw he gave instructions to do it without one, but now I just don't get it.
I get the Vgs(off) for the JFET and calculate the drain voltage,then what? Should I put the gate directly at V+ and adjust the source resistor to obtain the calculated drain voltage?
Thanks!
Eugenio
Old 7th January 2008, 10:26 AM   #2
Markus2006 is offline Markus2006  Poland
Eugenio,
This is very well explained on the page you listed (at the bottom). If you know Vgs(off), you put a potentiometer in place of R5 (or R10) and change its resistance until you get on the drain of the transistor half of the voltage between V+ rail and Vgs. Then replace the potentiometer with a resistor of similar resistance. Take a look at the example calculation on this page.
Let me know whether it works because I also want to build this preamp.
Marek
Old 7th January 2008, 02:43 PM   #3
Default Think I got it!
Ok, I went back and took a look at it and I think I finally got it. I was confused because I did not know what the gate signal should be when looking for halfway between v+ rail and Vgs(off), but we dont need a signal at the gate I think. I'l try it.
By the way, Albert Kreuser answered a while ago an e-mail I sent him and suggested playing it by ear. Put trimmers in it and adjust for best sounding setting and then replace with fixed resistors. I'l try this too to see if it changes.
Let you know how it turns out.
Thanks Marek for making me take a second (or fourth) look!
Eugenio
Old 23rd January 2008, 09:03 PM   #4
Finally finished the pre-amp, worked great! A lot of range on the tone controls. Really recommend it. Thanks for all your help!
Eugenio
Old 6th February 2008, 12:47 AM   #5
unclejam is offline unclejam  United States
Pics of the build???
im getting ready to embark on this build myself and would like a point of reference
Old 7th February 2008, 09:05 PM   #6
I did take some pics but I don't have the camera here, I'l try to get it back this weekend and post them here.
Old 11th February 2008, 04:03 AM   #7
Alright thanks im looking forward to them
Old 3rd March 2008, 07:46 PM   #8
Default Photo.
Sorry for the low quality, Im waiting to get my camera back were I have better quality images, and to get a photo of the finished pre-amp.
The power supply is on the left, then the Mid select, and the main PCB. I used a case from a junked satelite receiver, the faceplate is aluminum, painted and silk-screened. In fact, at least 95% of everything including parts, case, etc. is recicled from junked TV's, radios, etc. I only bought the Jfet's, two knobs and the transformer.
Old 4th March 2008, 04:51 AM   #9
cool
Old 4th March 2008, 11:31 AM   #10
Brett is offline Brett
Brett's Avatar
How do you like the sonics?
Help finishing Albert Kreuzer's preamp!Hide this!Advertise here!
Extra outputs for A. Kreuzer's Preamp? Eugenio70 Instruments and Amps 1 10th January 2008 09:12 AM
albert kreuzer bass pre amp engel dela pena Instruments and Amps 5 4th January 2008 12:44 AM
Ping Albert from Canada Shoog Tubes / Valves 0 18th May 2007 09:03 AM
Albert Kreuzer preamp scottyd Instruments and Amps 3 24th January 2007 02:46 AM
Jazz artists like Albert Collins Vivek Music 9 15th April 2004 06:03 AM
Copyright ©1999-2017 diyAudio
