Instruments and Amps Everything that makes music, Especially including instrument amps.
Bass amp head trips power at switch on
Old 23rd November 2007, 03:38 PM   #1
gazsp is offline gazsp  United Kingdom
Default Bass amp head trips power at switch on
Hi all,
My bass amp head sometimes trips the power when I first switch it on. This only happens at one venue in particular, and it really gets on the sound engineers nerves!
Just wondering if there's anyway I can modify the amp to stop it doing this. The amp in question is a Behringer BX4500H. I've read in other places on the net that other users of this amp have experienced the same problem.
Any info or suggestions would be most welcome.
Gaz.
Old 23rd November 2007, 09:23 PM   #2
Nigel Goodwin is offline Nigel Goodwin  England
Presumably these venues are using MCB's instead of fuses? - MCB's are really too sensitive, we had to take them out at work and refit fuse holders.
But that's obviously not a help for your problem
What you could do is fit a slow start circuit in the amp, these used to be fairly common in big amplifiers, particularly with toroidal transformers - if your is toroidal?.
Essentially you wire a high wattage wirewound resistor in series with the mains transformer primary - this then limits the input surge to the transformer - after a couple of seconds a timer circuit shorts the resistor out, using either a relay or a triac. This drastically reduces the surge when you plug it in - and should cure your problem.
Have a look here for a more detailed explaination, and suitable circuits.
http://sound.westhost.com/project39.htm
Nigel Goodwin
Bass amp head trips power at switch onHide this!Advertise here!
Yorkville 400B Bass Head Repair Help cm961 Solid State 0 20th February 2009 03:47 PM
Adding a 12V power trigger switch to Electrocompaniet Power Amp maxzimum Solid State 0 11th April 2008 02:54 PM
Peavey MarkIII bass head schematics??? Zero Cool Instruments and Amps 0 2nd February 2007 03:44 AM
car head-unit to run home power amplifiers tinkerbell Everything Else 1 30th December 2006 12:31 AM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 09:23 PM
