Instruments and Amps Everything that makes music, Especially including instrument amps.
5 pin din power supply?
Old 26th September 2007, 11:26 AM   #1
Trojan is offline Trojan  United Kingdom
Default 5 pin din power supply?
Hi folks, I have an old flanger by electrolabs and it sounds great. The problem is that it takes 2 x 9v batteries and as I am gigging with it I need to figure out how to supply it with mains power.
It has 5 pin din input sockets either side and little plastic lugs - presumably for attaching other units to it. If anyone out there has any thoughts on this I would be most grateful for your advice.
Old 26th September 2007, 01:09 PM   #2
Nigel Goodwin is offline Nigel Goodwin  England
The connections on the side are for linking other effects pedals together, so you don't have to link them via jacl leads. I don't know if they tranfer power as well or not?, but it would be simple to add an external power socket to it - bear in mind you need a +9V/0/-9V split supply.
I've got exactly the same pedal, my daughter got it from school as they were throwing it out.
Nigel Goodwin
5 pin din power supply?Hide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Copyright ©1999-2017 diyAudio
