Instruments and Amps Everything that makes music, Especially including instrument amps.
Edcor In SE Guitar Amp
Old 13th September 2007, 06:09 PM   #1
Trout is offline Trout  United States
Trout's Avatar
Default Edcor In SE Guitar Amp
I have been tweaking / playing around with a simple Guitar amp design using the Edcor XSE 15-8-5K transformer trying to get a good sound using a cathode biased 6V6 and switchable for 6L6.
Right now, In the 6L6 switch position I get a really nice balanced sound. Plenty of clean headroom and excellent volume.
In the 6V6 position, Things are not exactly as I hoped.
The clean headroom is lower, which I expected, But it is rather Fizzy when distorting in the upper volume ranges.
I suspect it is not biased for correct dissapation, But it is common in guitar amps to hit 6V6's pretty hard.
I am using JJ 6V6S which can handle voltage extremes pretty well, but it still seems a bit hot. No red plating is occuring even after prolonged use, But tube life might be an issue.
Any input would be appreciated. I listed the voltages for the 6V6 on the schematic.
SE Amp W/Edcor
Thanks!!
Trout
Old 13th September 2007, 08:48 PM   #2
Geek is offline Geek
Geek's Avatar
I found this behavior too when designing my "Roctal" 6V6 SE amp. Try cutting the voltage on G2. I used 15K/2W, then bypassed with a 10uF cap.
Cheers!
Old 13th September 2007, 09:25 PM   #3
Trout's Avatar
Cheers!
I can try that pretty easy.
What do you think about raising the Cathode resistor a bit more?
I had started at 470R and felt it was way to hot. The 680 seemes better.
Is there actually a limit how high I can go?
Trout
Old 13th September 2007, 11:13 PM   #4
Geek's Avatar
You'll pretty much start losing power with little change in sound, other than it's start getting raunchier earlier. I use 560 ohms on these, bypassed with either 330uF or 1000uF (depending on how much bottom you beed).
Cheers!
*edit*
To help you see what I did, here's Roctal's schematic:
Old 13th September 2007, 11:39 PM   #5
Trout's Avatar
Cheers!
Very interesting design there!
I noticed your much lower voltages also.
300V anode
290V screen
I am about 100V over that in this amp. which is where my bias voltage caught my attention.
With the 6L6GC installed my voltages are lower, but the sound is outstanding. I hope I can find a compromise.
I hate to swap out the bypass cap, Silly me I used a single cap and just alternate the resistor Via the switch like on the schematic I posted above.
The 25UF is great on the 6L6GC.
Old 14th September 2007, 04:05 AM   #6
Geek's Avatar
300V anode
290V screen
Thanks!
Yeah, they are two different animals.
I've run 6V6 as high as 370V in PP for a true "18W" output amp. On the bench test, she lost darn near 10% emission in a few days when run at 380V or more at 12W plate dissipation (RCA, Sylvania and Reflektor tested).
You could SPDT a switch in there to:
1) Change cathode resistor + cap
2) Change B+
Another thought for you.... I found if a 6V6's supply is too tight, it won't "sag" well at high drive levels and fuzzes up, as well as too tight a screen.
Whereas.... a 6L6 can sag anything but SS diodes and regulator
Cheers!
Old 14th September 2007, 04:49 AM   #7
Trout's Avatar
I was looking at The Champ 12 schematic and they show 480V on the anode. But I suspect not all the listed voltages are correct.
The screen is set at 242V?? Looking at the Power supply I do not see how they could possibly be that low , 27V on the cathode is about where I would have expected.
http://www.ampwares.com/ffg/schem/champ_12_schem.gif
I guess it will be tough to find a happy spot between the 2.
Trout
Old 14th September 2007, 07:10 AM   #8
Geek's Avatar
V3 in a Champ 12 is an EL34 though, isn't it?
Old 14th September 2007, 01:00 PM   #9
Trout's Avatar
Output:10-12 Watts
Preamp: 2 x 7025
Power: 6L6GC
Bias: Cathode bias
Rectifier: Solid State
My Bad, I thought it was 6V6 because I had one here to swap a speaker out and the guy had a JJ6V6S in it. I never thought to check the tube chart.
http://www.ampwares.com/ffg/champ_12.html
Trout
Old 14th September 2007, 11:59 PM   #10
Geek's Avatar
6L6 - right!
Last few Champs I saw had EL34's in them - a common mod.
*makes note to snoop at the local L&M for stock amp notes*
Edcor In SE Guitar AmpHide this!Advertise here!
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 03:16 AM
EDCOR Releases Line of Guitar OPT's Geek Instruments and Amps 33 6th February 2009 02:13 PM
Edcor Transformers Sal Brisindi Tubes / Valves 18 11th November 2007 02:08 PM
Edcor OPT's w/ SimpleSE awhite1159 Tubes / Valves 52 29th September 2007 03:00 PM
Edcor OPT's bloozestringer Tubes / Valves 23 3rd January 2007 06:27 AM
