i'm repairing an old peavey amp which has blown the pnp driver/output stage, the the four output transistors, mj15025 are easily obtainable, but the driver MJ15021 (70471180 1 amp.180 volt. PNP. TO3) seems to be obsolete,
at least in the uk.
can someone please suggest an equivilent
many thanks
doug
at least in the uk.
many thanks
doug
ON Semiconductor suggests the MJ15025 to replace the MJ15021.
The MJ15021 looks like it was the die from a MJE15032/33 mounted in the TO-3 package.
If after checking with Peavey and I found I still needed a part, I would look at the MJW1302, the lead spacing is correct too.
