R15 = 100R , R9 = 33R
it could be wrong ...
I have found the answer on :
http://www.carlsbro.com/
(it seems an enough common problem... )
The value can also be understood by resistor position on PCB..
bye
bye
Hi Gold_xyz!
Thanks a lot, if I had been clever enough I would have done same thing as you did, search at theirs forum
Yes it seems like a common fault with these amps.
I'll check the other transistors as well since those burnt resistors are in the bias circuit.
Thanks again!!
Bjorn
Thanks again!!
Bjorn
Hi Gold_xyz!
Thanks again!!
Bjorn
Hi I was wondering if you could let me know the value of the resistor r33 as I cannot find a circuit, it is from the same amp. thanks Peter, (Pitagi)
