Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th April 2007, 11:14 AM   #21
Originally posted by freddi
hi Snikpout - do you think Omni 15's bass section (and
perhaps the whole cabinet) would be good for home stereo?
Originally posted by Nigel Goodwin
Most probably not?, musical instrument speakers and HiFi speakers
are completely different items, with completely different purposes.
Unlike a lot of bass cabinets the Omni15 would also make a pretty
good PA loudspeaker. Any good PA speaker for home use with a
decent amplifier is capable of playing at mind-numbingly loud levels.
At sensible levels a PA speaker struggles against a hi-fi speaker
and basically has poor bass extension for the cabinet size, but
they can be the only loud option for flea powered amplifiers.
/sreten.
Old 27th April 2007, 11:36 AM   #22
Most probably not?, musical instrument speakers and HiFi speakers are completely different items, with completely different purposes.
I wouldn't bet on this one. German mfgr "Glockenklang" once built a high-quality threeway bass-box. The standard setup was in stereo BTW.
Charles
Edit: You will find a picture of the setup in the upper part of the following document:
http://www.glockenklang.de/pdf/de/prospekt-03-06.pdf
Old 27th April 2007, 12:14 PM   #23
Originally posted by phase_accurate
[B]
Like I said, designed for different purposes - a bass guitar cab is designed for maximum volume from the bass guitar, a HiFi speaker is designed for maximum quality and bass extension, and sacrifices volume to achieve it.
But interesting looking speaker though - I wonder how well it worked?, and if it was intended for bass guitar or multi-purpose use?.
Nigel Goodwin
Old 27th April 2007, 12:20 PM   #24
It was actually aimed at bass-players. The whole setup was exorbitantly expensive, in the order of a small car back then. It seems that it was quite heavy and impractical. But a tester remarked that it was basically a high-quality and high-SPL stereo.
I am of course aware that stage equipment is optimised for the most SPL per -buck, -kilo, -watt etc.
But hearing a bass played through a system that is really broadband, low distortion and high SPL is quite a treat.
Charles
Old 27th April 2007, 12:25 PM   #25
Hi, definetely not your average mono 4x10 + 1x15 stack, /sreten.
Old 30th April 2007, 02:28 PM   #26
freddi is offline freddi  United States
freddi's Avatar
maybe the tapped horn thread will lead to modeling mutual-load cases like Bill's Omni.
here's what I've got laying around - not much rear chamber so cutoff is very high
Old 30th April 2007, 02:32 PM   #27
Don't like those cabs but I like the instrument !
Charles (playing a DMZ 6000B)
Old 30th April 2007, 03:49 PM   #28
freddi's Avatar
I really like metalnecks. wonder who was responsible at Acoustic to build Transylvania Power khyboe (I think) copies? Freddy
ps - no low end - ok kick
115bk with EV15L
http://img239.imageshack.us/img239/8523/115bk15lpe3.jpg
single tone distortion down to 63 with 20vrms
http://img373.imageshack.us/img373/8...20vrmswjs9.jpg
Beginner - Building a bass guitar cabinet richmoore1998 Multi-Way 3 27th December 2008 02:31 PM
electric bass guitar impedance and level jenks Instruments and Amps 17 10th April 2008 05:38 PM
building an electric guitar? :) pinky78 Instruments and Amps 11 22nd March 2006 11:57 AM
onboard electric guitar/ bass preamp LJOE1969 Instruments and Amps 2 24th March 2005 05:33 PM
L-T subwoofer for electric bass amp? BAM Subwoofers 2 19th May 2003 09:37 PM
Page generated in 0.10824 seconds (75.41% PHP - 24.59% MySQL) with 11 queries
