Marshall 100v 8100U Guitar Amp Hums - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 29th January 2007, 02:20 PM   #1
DreadPirate's Avatar
Default Marshall 100v 8100U Guitar Amp Hums
I'm guessing somewhere out there is a forum for guitarheads that like to work on gear, if anyone knows of one, please let me know.
Amp is 1995 vintage. This guy came with broken volume and contour pots, pretty beat up. I replaced with identical Marshall parts and I think I did this right, at least the hi and lo values match up with the others. The only other thing I did was add solder to C62, it looked like there wasn't any on one of its legs.
I don't play guitar and do not have the proper connectors to test. I used walkman headphones in both the line out and rear output jacks all I get is a hum/buzz. I plugged a microphone into the input jack, no result on the outputs, same noise. I adjust all controls and push buttons, no effect, just hum/buzz. Am I just testing this wrong?
What is the function of the send/return jacks?
I did take a dc measurement at the output jacks, got steady 18mv.
The schematics are here, the pdf files are easily expanded and they look pretty good actually:
http://www.drtube.com/marshall.htm#VS1
Three General Questions:
1. The tube is there, it is original and lights up. Is there any way by looking at it to determine if it is operating properly? I do not have a spare tube.
2. I hear talk of filter caps, are these C61 and C62 and usually close to the transformer? These checked out with the esr meter, they are good. Note comment about added solder.
3. I also hear there are "coupling caps", how do you find these on the schematic? Do they come in pairs like filter caps?
Guitar amp problem (marshall 8080 valvestate) Palmu85 Instruments and Amps 3 26th September 2011 09:33 PM
Marshall guitar amp. Upgrade IC's recommendations Joelg Instruments and Amps 8 22nd January 2009 11:48 PM
SERIOUS TROUBLE: Marshall Valvestate 100v 8100 RevDEAD Instruments and Amps 1 2nd March 2006 07:59 PM
FS: 82000uF/100V; 56000uF/100V gengis Swap Meet 0 6th July 2005 03:17 AM
turning an ibanez guitar amp to a marshall electro samurai Instruments and Amps 0 5th June 2004 08:33 AM
Copyright 1999-2017 diyAudio
