Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 29th January 2007, 02:54 AM   #1
scottyd is offline scottyd  United States
Default Can anyone verify this onboard preamp?
I found this schematic online and I am really interested in building this type of preamp. Im just wondering if anyone has had success with this one before I order all the stuff. If not do you have any to suggest? Im more or less interested in 2 and 3 bands Thanks alot!
Easy Does It!
Old 29th January 2007, 02:04 PM   #2
teemuk is offline teemuk  Finland
Looks plausible: A pretty basic Baxandall circuit with added middle control. I would remove that 1uF capacitor from the input and drive the circuit with a directly coupled buffer that is made out of unused half of that opamp though.
Old 29th January 2007, 02:54 PM   #3
Interesting how would you go about doing that?
Easy Does It!
Old 29th January 2007, 03:20 PM   #4
I wouldn't worry about it, if you add a buffer to the front you still need the capacitor at the front of that. The Baxandall tone control really needs feeding from a low impedance source, so it depends what it's going to be fed from? - which is why he suggested the buffer.
This ISN'T a preamp by the way, its the tone control section from one!.
Nigel Goodwin
Old 29th January 2007, 03:29 PM   #5
Thanks for pointing that out. I could still use this setup with an active set of pickups though correct?
Easy Does It!
Old 29th January 2007, 03:55 PM   #6
The output from the jack should be low impedance, so would be OK - essentially it's already got a buffer IC on the output.
Nigel Goodwin
Old 31st January 2007, 03:54 AM   #7
Check this web site out: http://www.till.com/articles/GuitarPreamp/
Old 31st January 2007, 11:02 AM   #8
Yeah Ive seen that, Im going to build that one for sure, it should be fairly easy and straight foward. One question though, the author says if that thing is connected directly to a pickup it does not need R1. Does that mean that a jumper is put in its place or that particular wire from source to ground is left out all together?
Easy Does It!
Old 31st January 2007, 05:51 PM   #9
Just left out - but I would advise leaving it in, it wouldn't give any benefit leaving it out, except for the saving of a resistor!.
Nigel Goodwin
Old 31st January 2007, 06:58 PM   #10
Originally posted by Nigel Goodwin
...it wouldn't give any benefit leaving it out, except for the saving of a resistor!.
Actually in the concerned application it would. Magnetic guitar pickups benefit from very large input impedances - even more so do piezoelectric pickups. Rather replace that 1 Meg resistor with 10 megaohm one.
Edit: And by the way, if you really want this circuit to perform use something else than J201, i.e. 2N5045, 2N5434, 2N5452, 2N5457 or U309 (change source resistor to 3K3 with last one). Donald Tillman (the author of the circuit) substituted original FET (2N5457) with J201 just for better noise performance. In this circuit J201 has pretty poor headroom and it will take only about 500mVpeak input signal to overdrive it.
2-band bass guitar onboard preamp phil mailloux Instruments and Amps 71 23rd August 2011 08:55 PM
Making and onboard bass guitar preamp Skywalker83 Parts 7 3rd December 2008 08:42 PM
Low TIM, How to verify it!!! thanks a lot!! mclarenpingu Solid State 10 19th March 2008 01:39 PM
onboard electric guitar/ bass preamp LJOE1969 Instruments and Amps 2 24th March 2005 05:33 PM
Page generated in 0.10256 seconds (82.64% PHP - 17.36% MySQL) with 11 queries
