Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 20th January 2007, 06:55 PM   #1
VvvvvV is offline VvvvvV  United Kingdom
Default modifying MIDI circuit boards/patching into consumer keyboards?
I am looking for a MIDI controller keyboard where I can hack into the faders and keyboard contacts and extend them about one meter out to an outboard circuit.
the trouble is that most of them seem to use really complicated velocity sensitive keyboard circuits that are hard to mod at all.
I just hacked up a "Novation remote 25" keyboard which has about 30 MIDI-cc potentiometers, 30 keys and an XY pad.
when I got inside the keyboard contacts, it turns out that each key is activated by four contacts on each key, that look like the number four on a dice(:, plus a bizarre long ribbon connector that runs the whole length of the keyboard under all the keys but that doesn't look like it can make electrical contact with anything very oddly.
to activate a key, I have to join the top and bottom pairs of contacts for that key. I have hacked into the circuit and extended it into copper wires (from a mouse cable) that are about one meter long.
when I try and join the notes one meter away it is tricky getting the contact and then when it does it often hangs on a gate on.
is it really tough to hack into velocity sensitive keyboards?
is it unwise trying to extend circuit board contact for potentiometers and keys about a meter away from the commercial keyboard? Will the static buildup screw it up?
surely modifying commercial stuff is better because you get so many extras like USB, program/Channel changes, knobs and wheels and buttons etc...?
Old 21st January 2007, 11:21 AM   #2
here are some pictures of the beautiful insides of a MIDI keyboard.
1-confounding velocity sensitive note pitch/gate contacts.
What could the ribbon connector be?
Old 21st January 2007, 11:34 AM   #3
velocity sensitive double contacts, a line of rubber buttons with 2 contacts each is pressed by every key, each button has one contact higher than the other to sense velocity.
I can't seem to turn this into a basic note on/off system system even for only five keys.
Old 21st January 2007, 11:36 AM   #4
backside of the velocity board
Old 21st January 2007, 11:41 AM   #5
the potentiometers, LCD display, etc
The keyboard plastic in the background is chunky, refined and impressive.
Old 21st January 2007, 11:43 AM   #6
underside of the keyboard with the strange ribbon connector
Old 21st January 2007, 11:51 AM   #7
main novation controller for the remote series into which the different controller/key panels are plugged, with USB/power, MIDI, all the keyboard IO.
The pitchbend XY wheel and the cheapo XY pad that you think would be the strength of this board are at the left, still an excellent controller.
Old 26th January 2007, 06:36 PM   #8
Send a message via AIM to laserbeak Send a message via Yahoo to laserbeak
well those are very interesting pics but i'm sorry i cant help.
i found this searching for midi tutorials :P
Old 13th February 2007, 03:29 PM   #9
thanks for the encouragement, in any case, I figured out what the ribbon is going along the length of the keys, it is a resistor that measures channel aftertouch which is a mono MIDI message
I also found that there is no easy way of turning the contacts from any commercial MIDI controller with velocity sensitivity into basic note on off keys like to get on a DIY MIDI board, unless you are really a mad electronics buff it is literally a type of electronic shafting for anyone that triesbecause all the velocity sensitive contact go into a really fkkkkt bastard microcontroller
however if you really wanted to you could use some of the Midi potentiometers and remap them somehow, if you have some kind of program, into keys and use them as switches.
Old 14th February 2007, 03:00 AM   #10
Optical is offline Optical  New Zealand
Haha, you are doing exactly the same thing as I tried to do 2 years ago with my edirol PCR50
those stupid pads are almost impossible to reengineer
i was trying to make the keys into piezo trigger drum pads for an eDrum kit.
Basically to register a key press the switches close a few milliseconds apart, and the micro deciphers the time difference as the key velocity.
I had made a ramping signal that ramped according to the voltage peak of the piezo (peak hold cct into constant current ouput opamp charging a capacitor if i recall), then triggered two comparators as it ramped up. then the ramp reset after the second comparator had triggered. but it required 5 opamps, a few transisitors and a whole lot of mucking around tuning the ramp times etc. in short, it worked terribly. perhaps good in theory though
What are you extending the wires to do? I ended up building this http://www.edrum.info/ to make my edrum set and it was much simpler and worked straight away haha
plus my keyboard stayed intact
Modifying 100 watt LXI amplifier circuit CrazzyAbtTubes Solid State 19 30th November 2009 01:17 AM
Help modifying circuit Rob11966 Tubes / Valves 14 3rd November 2008 05:14 AM
Modifying 200W gainclone circuit soundNERD Chip Amps 3 6th July 2006 01:58 AM
Page generated in 0.11539 seconds (87.20% PHP - 12.80% MySQL) with 11 queries
