What is the power rating of the Peavey 300SC output BJT??? - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th January 2007, 12:54 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Question What is the power rating of the Peavey 300SC output BJT???
Part numbers are 700x4140(x=7 or 8 for both polarities) which I think is 140V 4A.But dont know about the power rating for these TO-3s.
Old 8th January 2007, 02:24 AM   #2
d3imlay is offline d3imlay  United States
The CS 400 & 800 used Mj15024 &15025. I recently tried contacting Peavey for some info. They'll be happy to take your phone order during their 9-5 bankers hours. Forget anything else.
Old 8th January 2007, 06:06 AM   #3
unclejed613's Avatar
back when i had a pile of them, i used MJ15022 and 23 transistors for "general replacement" output devices on guitar and PA amps. the 15024 and 25 have better max ratings than the 22's and 23's, so if i had my 'druthers, i would use them, but don't use one to just replace one transistor of the output set, replace the whole set. you will need to readjust the bias, but otherwise, they should work fine, maybe even better than the originals.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 8th January 2007, 06:46 AM   #4
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
7 is PNP, 8 is NPN.
Here's the whole cross reference. Don't substitute without this list.
http://manuals.schematheek.com/sheet...%20replace.pdf
/Hugo
Old 8th January 2007, 02:05 PM   #5
Originally posted by Netlist
7 is PNP, 8 is NPN.
/Hugo
Netlist, what a cool xref.
Many thanks
Old 8th January 2007, 02:14 PM   #6
pinkmouse's Avatar
Those Peavey's are nice robust amps. Well worth fixing.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Peavey pv2000 power amp e_c_mccollum Instruments and Amps 6 18th January 2010 03:18 AM
A Question Regarding Peavey's CS 800 Power Transformer OMNIFEX Instruments and Amps 8 11th May 2009 06:13 PM
PLH output capacitor rating gbullimore Pass Labs 1 4th October 2007 09:42 PM
Peavey PA cabs - change ohm rating? Skyline_UK Multi-Way 0 18th June 2005 02:36 PM
Copyright 1999-2017 diyAudio
