diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   Guitar amplifier wierdness (http://www.diyaudio.com/forums/instruments-and-amps/91520-guitar-amplifier-wierdness.html)
Frazzled 3rd December 2006 04:37 PM
I purchased a guitar amp yesterday and opened up the chassis today to clean out the dust and crud and I found two resistors that have had one leg clipped to remove them from the circuit.
If you look at the schematic HERE look at R102 and R105 on the base of Q1 and Q2 respectively.
Any ideas why one side of the resistors would be lifted from the circuit?
Thanks,
Don
anatech 3rd December 2006 06:40 PM
Hi Don,
Believe it or not, the over current protection circuit was removed! Check the emitter resistors for the correct value and reinstall those resistors.
-Chris
audiofan 3rd December 2006 06:42 PM
This is a protection circuit modification to get more power before protection get in and limit current around 150% of initial rating
anatech 3rd December 2006 06:49 PM
Hi audiofan,
I figured as much. It's still a stupid thing to do. The original designer had the limit designed in for a reason. I could see the protection being backed off a little, possibly a time limit out in to delay action. Disabling the circuit entirely is the wrong way to go about it.
-Chris
Frazzled 3rd December 2006 08:02 PM
GEEZE!
I wonder if this was done to hide a problem with the amplifier or strictly for more power...
Well as you can see they're 3.3k resistors... I'll be re-installing them shortly, I'll let you know what happens.
Thanks,
Don
djk 3rd December 2006 10:22 PM
"I could see the protection being backed off a little, possibly a time limit out in to delay action. "
The 100F caps should delay the VI limiter long enough so that it doesn't activate on any musical signal, but still protects in the event of a short.
At least Fender used three sets of outputs, not like the newbies here that think they can run one set and have the amp hold together.
Grounded output stage, makes for a simple drive circuit.
Some current feedback, the later Carver M1.0T used a similar scheme.
anatech 4th December 2006 01:48 AM
Hi djk,
Yes, but Carver found the current feedback affected the gain greatly with even 1% components in the feedback loops. They therefore used a pot which caused them more grief further down the line. Just did an M 4.0t for that. ;)
I still think disabling a protection circuit completely is not intelligent.
-Chris
Frazzled 4th December 2006 01:51 AM
OK but looking at the circuit it is not completely disabled only partially right?
anatech 4th December 2006 02:03 AM
Hi Frazzled,
It is for the one pair. The proper solution would be to either change all those resistors to another value, or fix the specific problem that caused the amp to go into protect (assuming the tech couldn't find the problem due to high or open emitter resistors). There is no guarantee that those transistors will current share given how that stuff usually gets fixed.
djk,
Maybe not. These amps do not reproduce music. Often they are run into sustained clipping. Therefore what we instinctively have a feel for does not apply to guitar amps sometimes. I had to think about this a little.
-Chris
djk 4th December 2006 06:27 AM
The delay looks like 500mS or so, and the current about 10A peak. Looks like it could pass a 400W squarewave at 4 ohms for an indefinite time, but go into limiting on lower impedances.
Resources saved on this page: MySQL 18.75%
